Old 04-26-2009, 04:04 PM   #1
Frank Graham
Drives: 2007 Yaris
Running with oil plug out
Best friend's 2007 Yaris had the oil changed at some quicklube joint which, apparently, left the drain plug loose. They also didn't reset the "maintenance due" light, which caused her to not pay attention to the "check engine" light. At the stoplight last night, engine stopped. Bottom line: the engine was run without any oil for some time. Currently will not start (oil plug and filter replaced, coolant topped up). Only one computer code: P0012 ("A camshaft position - timing over-retarded (Bank 1).
Is this hopeless?
Frank Graham is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
