Old 05-18-2009, 04:09 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Non interference engine
My Echo has surpassed 200k and as the Yaris has a similar/same engine i was wondering if these engines will eat the valves if the timing chain breaks..
Old 05-18-2009, 09:28 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I'd bet on it going "CRUNCH!" It has a 10.5:1 mechanical compression ratio, which doesn't leave a lot of clearance space, and the valve notches on the pistons don't look that deep to me.
Is there a service recommendation for replacing the chain?
Old 05-18-2009, 10:49 AM   #3
jambo101
jambo101's Avatar
Owners manual says to replace at 160,000kms and i now have over 200,000kms
If i were going to keep the car i'd be thinking replacement but i'm hoping to trade it in for a newer Toyota in the next month or so.
Old 05-18-2009, 12:31 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Trade, you got your money's worth.
Old 05-18-2009, 12:48 PM   #5
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
that's a large risk you're willing to take, i'd trade it in sooner rather than later if that's the case. as for the damage, I doubt it
Old 05-18-2009, 10:55 PM   #6
you must be smoking GOOD stuffs... Maintenace manual does not state timing CHAIN replacement.
Old 05-19-2009, 12:32 AM   #7
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
timing chain does not need to be replaced at 160K
the chain should last the life of the engine providing you are using a quality synthetic
BELTS however do need to be changed the Yaris does not have a timing belt
Old 05-19-2009, 04:24 AM   #8
jambo101
jambo101's Avatar
Talking about the Echo not the Yaris.
Old 05-19-2009, 08:20 AM   #9
same engine. no timing chain maintenance required.
Old 05-19-2009, 08:48 AM   #10
DerFlosser
DerFlosser's Avatar
I believe it to be an interference motor so, if the chain or tensioner(s) failed, the motor would be toast but as stated, there is no service recommended for the timing chain or the guides. A quality synthetic helps greatly and that's why I stick with a little heavier oil in the car as well.
DerFlosser is offline   Reply With Quote
Old 05-19-2009, 09:42 AM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
as already stated:
1nzfe = interference
chain does not need replacing. you'll spend more money on parts and labor installing a new chain than you would for a low mileage longblock lol
Old 05-19-2009, 11:06 PM   #12
GeneW
Drives: 2008 Yaris
Not having the benefit of tearing one of these things down I still suspect that if the chain "breaks" that you're talking metal fragments suddenly being churned into the oil. Not cool for the bearings or VVT mechanism. Why do I suspect that valve work will be just a sideshow in a circus of mechanical mayhem?
Gene
Old 05-19-2009, 11:08 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
Gene
it will
fortunately a complete engine can be had for under $400
that's less than most members blow on exhaust systems lol.
Old 05-19-2009, 11:10 PM   #14
GeneW
Drives: 2008 Yaris
it will
$400 for a complete motor or a junk yard salvage?
How about for an AT?
Gene
Old 05-19-2009, 11:21 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
Gene
junk yard low mileage engine
www.car-part.com
Old 05-20-2009, 05:31 AM   #16
jambo101
jambo101's Avatar
I like learning new stuff. Went back and reread the owners manual and timing chain has no replacement interval, dont know where i got that 160kreplacement figure but i suspect it might have been something the salesman said when i bought the car.
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
Interference or Non-Interference Engine TheMaskedMan General Yaris / Vitz Discussion 14 03-28-2007 10:09 AM
