Old 03-26-2007, 02:04 PM   #1
TheMaskedMan
Drives: 92 Toyota Camry
Interference or Non-Interference Engine
Is the engine in a 2007 Yaris a interference or non-interference engine?
TheMaskedMan is offline   Reply With Quote
Old 03-26-2007, 03:31 PM   #2
clayky
Drives: '07 Yaris S Sedan
Probably interference being it's chain-driven. On the other hand I doubt you'll ever have to worry about it.
clayky is offline   Reply With Quote
Old 03-26-2007, 06:17 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Why do you wonder? Chain driven or belt driven has nothing to do with it being interference or non-interference as both can be either. Most modern engines are interference, however, I wouldn't worry about it. The yaris is chain driven with no scheduled maintainance.
Old 03-26-2007, 06:38 PM   #4
Kitt
Kitt's Avatar
has anyone ever wonder why did they designed it chain driven? nothing against that of course... just wondering...
Old 03-26-2007, 06:38 PM   #5
acrbill
Drives: Polar White Hatch
With 10.5:1 compression its a safe bet to say its interference.
Old 03-26-2007, 06:53 PM   #6
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
It's interference.
Chain driven engines are more reliable (especially with variable timing setups) and cheaper to maintain than belt driven engines.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-26-2007, 09:21 PM   #7
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Unless the chain breaks at highway speeds....then you're screwed.
jdubau55 is offline   Reply With Quote
Old 03-26-2007, 10:20 PM   #8
Kitt
Kitt's Avatar
that must hurt
Old 03-26-2007, 11:12 PM   #9
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
belts are a pain!
Before this I had a '94 geo prism (toyota corrolla). The timing belt had to be changed every 60k miles, and the water pump failed at 60k intervals too.
fu_im_from_texas is offline   Reply With Quote
Old 03-26-2007, 11:25 PM   #10
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
yeah, my 86 gti had a timing belt. never again will i own a car with a timing belt.
chain driven all the way!
tekmoe is offline   Reply With Quote
Old 03-26-2007, 11:42 PM   #11
PetersRedYaris
I wouldn't have bought a Yaris if it had a timing belt. Low maintainance was a big selling point for me. Timing belts are a scam IMO. It pisses me off how a car company can design a car with a $500-$600 60,000 mile belt change. Toyota is of course not that expensive as they are the only company to offer flat rate timing belt changes depending on 4, 6, or 8 cylinder. I've owned Mitsubishi (Montero) and Nissan (Pathfinder) vehicles and $700 is not uncommon for a T-belt service. I get angry just thinking about it.
Old 03-27-2007, 08:06 AM   #12
TheMaskedMan
How often do you have to change the chain? and if it breaks are you screwed like you would be if a belt broke?
Old 03-27-2007, 01:45 PM   #13
Nautical Yaris S
1.5L of FURY!
Drives: 2007 Yaris S Sedan, 5 speed
no timing chain maintenece is listed in the owners manual.
think of the older cars from the 60s and stuff. those engines still run w/ no overhaul because they all have chain-driven cams. unless the chain goes out of tolerence and skips a gear, you are fine. but i cannot see that happening unless you are running 22lbs of boost, or a 200 shot of Nitrous... bboth of which would blow the bottom end before the timing chain broke :)
Nautical Yaris S is offline   Reply With Quote
Old 03-28-2007, 12:39 AM   #14
PetersRedYaris
Never, NO scheduled maintainance. IF it broke, yes, you would be screwed. I have NEVER heard of that happening on a Toyota, however.
Old 03-28-2007, 10:09 AM   #15
redyaris
Shiny Chromey Coolness
redyaris's Avatar
OMG...no timing belt change required?!?!?!? There is a GOD!
It just gets better and better. Im glad I bought this little car.
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
