#1 |
![]() ![]() ![]() Drives: WRX ,Tacoma and Yaris Join Date: Apr 2006
mileage getting better
I have 2000 miles on my Yaris hatch. The mileage is getting better. First tank was about 34 mpg, my last tank was 36mpg. This is around town and mostly short trips ( less than 10 miles), also ac on most of the time.
"PERCEPTION IS SELECTION"
![]() ![]() Drives: 2007 Liftback Blazing Blue Join Date: Aug 2006
My break in point seemed to end at about 4k miles. change to synthetic oil at your 5k mile oil change. Inflate your tires to sidewall pressures.
#3 |
ugh
And mine just keep getting worse.... passing 8000 miles on it now.
Instead of the increasin miles at start, from 33 to 26 myself, today I was scared to see at 140miles the tank is half way..... usually its 180-210 before it indicates that... wtf is going on, all my tires are fine, and I didnt add anything in the past few gas tanks....
#4 |
Over 62mph and the mpg plummets. Synthetic oil helps a bit. Examine your driving style and maybe invest in a scangauge.
#5 | |
Small Car Lover
Also remember extra stuff in the car reduces mileage (weight), roof rack of any kind reduces mileage (drag), having your windows open (more so at high speeds like highway kills mileage), keep a consistant speed as possible, also remember short trips where the engine doesn't fully warm up effects mileage. Just food for thought! Hope it gets better!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. Last edited by ECHOKnight2000; 09-17-2006 at 07:05 PM. |
#6 | |
![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
if you have manual trans, try shutting the engine off and coasting in neutral to stop lights that you know to be long. |
#7 |
mines getting better too!
#8 |
Using ethanol 10% mixed could cause a drop as well. At some point we will have no choice.
#9 | |
![]() Drives: 2007 Yaris Sedan Join Date: Sep 2006
mileage, but you say no? |
#10 |
Scangauge has mpg and spd as well as 2 other settings on the same screen. It starts going down at about 52-53mph at 62 it just drops all the way off. To hold the yaris at 63-65mph you are getting like 28-32mpg. At 55mph the yaris is getting about 42mpg. This is in the automatic the manual may be different. At 60mph it is only turning 2600rpm. Cruise control would smooth this out a bit as well.
#11 | |
Hrmm
And I have too much junk in the car aswell that I have to get rid off. I will wait till this tank is done, refill, empty the car out of all its junk(except my system), and drive at the most of 65mph for the whole tank and I will let you all know what I get again next week.(I say this cause this week will be almost all highway driving.) |
#12 | |
#13 |
![]() ![]() Drives: Yaris 5Dr. Join Date: Sep 2006
I got 14 km./litre
#14 |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
while driving on the high at 70mph-105mph on an engine that's already warmed up, I've been getting about 34.5mpg on a manual transmission.
#15 |
Bears eat beets.
Drives: Yaris LB Join Date: Aug 2006
just got my best tank yet at 42.3mpg (US)
tires @ 44psi highway: 55-60mph city: lots of neutral coasting dont use the A/C ill switch to synthetic oil at my next oil change...
Free veggie starter kit! |
#16 | |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
The early bird gets the worm, but the second mouse gets the cheese. |
#17 |
In the automatic coasting in neutral alleviates the drag from the trans when in gear. Allows for a higher coasting speed. The length of coast is extended as well.
On my 5spd Geo I always coasted in neutral, and the results were higher as well. The scangauge shows this instantly. The rpms of both cars drop below 700 in neutral. |
#18 | |
Bears eat beets.
| Fuel Economy Poll | pennystocks | Fuel Economy Forum | 42 | 01-28-2013 12:10 PM |
| Gas mileage and A/C | Chaad32 | General Yaris / Vitz Discussion | 18 | 01-29-2009 04:31 PM |
| Tired of poor gas mileage & buying premium gas. | Boosted Peon | New YARIS Purchase Forum | 29 | 08-25-2006 08:59 PM |
| Excel gas mileage calculator | AlexK | General Yaris / Vitz Discussion | 1 | 08-13-2006 11:42 PM |
| Fuel / Temp / Mileage Gauge - Special LED Readings? | bigsky2 | General Yaris / Vitz Discussion | 3 | 05-31-2006 09:04 AM |
