Old 06-27-2009, 05:15 PM   #1
llimonce
Drives: yaris sedan
Flywheel
hi
i have a yaris sedan with pullies , k&n , sway bar , and header ..
what are the benefits with the flywheel ?? it produces vibrations ??
Thanks
llimonce is offline   Reply With Quote
Old 06-27-2009, 05:27 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I read somewhere that it rattles?
Old 06-27-2009, 05:30 PM   #3
llimonce
Drives: yaris sedan
hi peterpoop
excuse my english but i canīt understand you ..
Old 06-27-2009, 05:30 PM   #4
I have the Fidanza flywheel. No rattling at all. (where'd you hear that?) The lighter weight frees up rotational inertia to increase responsiveness. It's just like a giant pulley in that respect.
A lot of work just for that though; unless you are doing more like a clutch or LSD at the same time.
Old 06-27-2009, 05:32 PM   #5
llimonce
Drives: yaris sedan
thanks cali yaris !!
Old 06-27-2009, 05:57 PM   #6
PETERPOOP
PETERPOOP's Avatar
I read it on a supra forum. Some guy was wanting to sell his supra and said there is a rattle. But he said he as common when running a lightened flywheel on any car. Oh well!
Definately one day if my clutch ever goes out, I'm forking out the cash for a LSD and lightened flywheel!
Old 06-27-2009, 08:22 PM   #7
06silveryaris
Drives: 2006 yaris
It should not rattle if its tight
06silveryaris is offline   Reply With Quote
Old 06-27-2009, 08:27 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
my fidanza (same as Garms) does not "rattle" (wtf are you reading peterpooop?). and i had to re-learn heel-toe as the revs drop off much faster than stock.
IMO not an investment i'd make again if i was looking for power. it's simply NOT WORTH THE $$$. however, if you're making more power and are installing a better clutch (please no Spec clutches http://www.yarisworld.com/forums/sho...ht=spec+clutch you might as well pick up the Fidanza. even bolted to the Spec stage 3 which is heavier than stock, you drop 5lbs off your rotating mass)
Old 06-29-2009, 11:26 AM   #9
llimonce
Drives: yaris sedan
i learned about reducing the weight from stock flywheel.. anyone ??
Old 06-29-2009, 12:04 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
what did you learn about it?
Old 06-29-2009, 12:58 PM   #11
llimonce
Drives: yaris sedan
sorry tamago, i hear about this..
here in my country the people they do with mustangs , chevrolet a more..
reducing the weight from the back side of the flywheel .. opose to the disc surface
Old 06-29-2009, 01:16 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
if you can find a shop who can lighten your stock flywheel for you safely and inexpensively i say go that route. :)
Old 06-29-2009, 01:27 PM   #13
llimonce
Drives: yaris sedan
that increases power ?? .. increases vibration at iddle ?? because i donīt like vibrations at iddle
Thanks again
Old 06-29-2009, 03:12 PM   #14
Mine doesn't vibrate, it shouldn't. Increase power? Not horsepower directly, but helps with increased responsiveness, just like the pulleys do. Your car will feel like it "wants to go", for lack of a better description. The tech heads can describe it a different way, I'm sure.
Old 06-29-2009, 04:29 PM   #15
BDD
BDD's Avatar
Drives: Poor with a nice bicycle.
The only time I've ever experienced a rattling in this area was with a multi-plate clutch (not on Yaris). I think having a rattling flywheel is a sign of malfunction.
BDD is offline   Reply With Quote
Old 06-29-2009, 04:31 PM   #16
llimonce
Drives: yaris sedan
i think the same opinion
Old 06-29-2009, 09:46 PM   #17
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Remember that is not just a matter of reducing weight... where do you reduce it is very important...
When talking about inertia and rotational mass... the weight on the outer side of the wheel is the most important.
I've seen the OE flywheel of these cars and there is some material that could be remove... but really not that much and almost non near the edge...
You have to be SURE the machine shop knows what they are doing... if they go crazy on the wheel it could break at high speed... not nice! (google broken flywheels)
Also make sure they balance the wheel to at least the original values...
Too much risk IMO
If you really want this, go buy a Fidanza.
flywheel question White Yaris DIY / Maintenance / Service 4 03-16-2009 09:34 PM
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
Flywheel HP to wheel HP andries General Yaris / Vitz Discussion 19 11-26-2008 07:03 PM
flywheel weight yarisdarkness Performance Modifications 19 10-30-2008 11:22 PM
How Heavy is the flywheel? jouslee DIY / Maintenance / Service 12 02-22-2007 02:18 PM
