Old 07-10-2009, 02:06 PM   #1
regal
neg camber
Anyone know how neg camber affects handling other than prevents rubbbing?
Old 07-10-2009, 02:15 PM   #2
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
I bought some camber bolts from Garm at Micro Image to help with my Auto Cross. The TruLube Yaris is points leader in my class (ST) so far, the camber adds to the handling esp helping decrease understeer, and combined with the TRD suspension and rear sway bar the car handles great.
Had I known I would have bought the Ultra Racing 23 mm sway bar Micro Image sells instead of the TRD.
Someday...so much to buy...
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 07-10-2009, 02:24 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
negative camber up front = sharper turn-in and overall improvement in turnability
negative camber in the rear = less oversteer.
you want a balance of f/r negative camber that gives you the type of handling you would like to fee.
you also want to play with tire pressures.
Old 07-11-2009, 01:29 AM   #4
regal
[QUOTE=Tamago;349875]
QUOTE]
Do you mean less understeer? I don't see how we would ever want less oversteer with this car, there is none to begin with.
Old 07-11-2009, 02:23 AM   #5
baked_limabeans
Drives: Polar White
if you add negative camber to the rear tires, the rear tires will grip better during turns hence causing the car to oversteer less.
that is what he means.
baked_limabeans is offline   Reply With Quote
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 12:11 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Camber Plates (Gauging Interest) misformartin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 01-07-2009 11:21 PM
