Old 07-26-2009, 05:16 PM   #1
GreenSpeed
Drives: '08 Yaris LB
Audiophiles-Need your .02
Hey guys,
I have a Pioneer Avic D_Series deck and ever since I installed it about 4-5 months ago, I've had a strange issue with it.
My amp and sub work just fine when I am playing the radio, but when I switch to my Ipod, either through the IPOD connector or the AUX jack, and even from CD's, the amp and sub don't operate at all! I figure it has something to do with the way I wired it, but I'm not sure where to start.
Can someone enlighten me?
Thanks in advance!
GreenSpeed is offline   Reply With Quote
Old 07-28-2009, 11:59 AM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
do your door speakers still work?
Old 07-29-2009, 02:02 AM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Just so I'm straight with what you're saying...
When you change the input and use the AUX/I-pod and occasionally when you put a CD in, the (sub) amplifier turns off?
Of course the first thing I'm thinking is a head ground point but there's probably another issue...it is a Pioneer. What year was it manufactured?
― Thomas Paine
Old 08-01-2009, 01:09 PM   #4
GreenSpeed
Thanks for the feedback...The door speakers still function when the aux cable is used, but not the sub which is only connected to the amp. The door speakers are running from the head unit, which is less than 2 years old.
It's really got me scratching my head.
Old 08-03-2009, 02:22 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
does the sub amp turn off.... can you see the power light turn off, or does it stay on?
If the light turns off.... are you using LOC's/High level inputs into your amp, or RCA's?
If the light stays on..... put your hand on the sub when playing bass heavy music and make sure you don't feel any vibrations.... there is a big difference between sub not playing, and playing very quietly.
Old 08-04-2009, 02:54 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Do you have induced noise? Especially when the dome light turns off?
― Thomas Paine
Old 08-05-2009, 02:59 PM   #7
Mobius1
Installer
Mobius1's Avatar
Drives: 2008 Yaris HB
Sounds like you are using the power antenna turn on (blue wire) to turn on the amps instead of the amp turn on wire(blue with white stripe). When you switch sources from tuner the blue wire stops supplying 12v while the amp turn on wire supplies 12v all the time.
Mobius1 is offline   Reply With Quote
Old 08-06-2009, 12:01 PM   #8
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
that sounds right....... forgot about power antenna wires (never have had to use one).
Old 08-06-2009, 09:26 PM   #9
GreenSpeed
Thanks for the tips...I'll pull the deck and see if that works.
5w20, My .02 Turbo&Auto DIY / Maintenance / Service 23 07-15-2007 06:31 PM
