Old 08-09-2009, 09:57 PM   #1
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
Painted my Engine Cover
Here are the pics.
I tried to stay simple and make it clean looking.
Blue
Blue_dragon_192 is offline   Reply With Quote
Old 08-10-2009, 03:22 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Nice.
Old 08-10-2009, 10:04 AM   #3
Blue_dragon_192
Originally Posted by echo_hrs View Post
I think it could benefit from a nice fine wet sanding, and another shot of clear...
Cheers
I think you are right.
Old 08-10-2009, 12:00 PM   #4
supmet
Drives: 2007 4 Door Yaris
Did you use house paint or something?? I'm scared to paint mine now.....
Old 08-10-2009, 01:02 PM   #5
Blue_dragon_192
House paint???? Not sure what you you are referring to.
I wet sanded the entire cover with 400 grit sand paper.
cleaned it and wiped it down with a tack cloth.
Sprayed it down with adhesion promoter and let it dry.
Then I sprayed it with Red Engine Enamel (gloss).
I wet sanded it down with 400 grit paper again, and then sprayed it with the engine enamel again.
I hand painted the black on the VVT-I and logo with gloss black.
I also sanded the nuts that hold the cover down and sprayed it with flat black and then clear (not high temp paint).
I like the orange peal look on the cover because it still makes it look plastic, like it was from the factory (in a sense).
Blue.
EDIT: Looked at my original photos and the Auto setting just did not do well, I will take pictures in daylight. I took the pictures at night in the garage.....
Last edited by Blue_dragon_192; 08-10-2009 at 01:05 PM. Reason: Update about the photos.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Question about painting the Engine Cover Blue_dragon_192 Cosmetic Modifications (Exterior/Interior) 11 08-05-2009 12:45 PM
Engine cover for S/C engine LtNoogie Cosmetic Modifications (Exterior/Interior) 84 05-04-2009 08:41 PM
Painted Engine Valve Cover: Round 2 m911gt Cosmetic Modifications (Exterior/Interior) 46 01-12-2009 08:17 AM
