Old 08-12-2009, 08:16 PM   #1
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
warped drums?
I am getting a pulsing feed back on my 2007 Toyota Yaris brakes. Light when driving and heavy when pushing down on the pedals. The local Toyota dealer repair department says that the front brake disks are warped from driving too little, and the problem is not covered by warranty. The repair department says that the problem is not dangerous. Of course some of the problem could be a alignment problem. Given the shape of the parking lot over the past 1 1/2 years (lots of pot wholes and lots of sand to get into the brakes) is this a warranty problem? The idea of having to pay to have my disks turned at 11,400 miles to get rid of the bump does not appeal to me. Will this problem correct itself? Should I take the Toyota Yaris to a speed shop and get the brakes upgraded? Should I take the Toyota Yaris to a regular brake shop and have the problem fixed? Should I file a complaint with Toyota USA over the issue? Should I file a complaint with the US DOT over the problem?
ellenbetty is offline   Reply With Quote
Old 08-12-2009, 09:01 PM   #2
supmet
Drives: 2007 4 Door Yaris
Toyota is good at excuses when it comes to the yaris brakes. They told me that the hills I lived in caused premature warping of the rotors. Which by the way, warped 5 times by the time I got to 1 1/2 years.
I just picked up R1 drilled and slotted rotors and carbotech pads from microimage, which so far have lasted much longer than the OEM.
Another option is to remove the rotors yourself and most machine shops will turn them down for 20-25 dollars.
Old 08-12-2009, 11:22 PM   #3
ellenbetty
ellenbetty
ellenbetty's Avatar
Landlady rules forbid do it yourself car repairs. Landlady likes to give fines for those who violate her rules.
Old 08-13-2009, 01:16 AM   #4
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Are you talking about the front or the rear. Your title says "Drums" and then you talk about "Disks" (aka rotors)? If your disks are warped then you will feel the vibration in the steering wheel. If the drums are warped then you should feel it in you butt more. Disks are more likely to warp unless you have driven with your E-brake on. Also they Disks and Drums can both be warped by over torque and uneven torque of the wheels
Old 08-13-2009, 11:11 AM   #5
i had to replace my rear drum pads when i saftied the car when moving back to ontario....likely cause: putting on the ebrake too hard
Old 08-13-2009, 11:44 AM   #6
RedRide
RedRide's Avatar
An interesting read on disk 'warping", etc.......
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old 08-13-2009, 03:17 PM   #7
markitect
I've heard before that after a sudden stop you let the car slowly roll forward some (whenever possible).
markitect is offline   Reply With Quote
Old 08-13-2009, 03:35 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Putting the parking brake on hard with the drums hot and expanded from recent hard braking will warp them as the drums cool and contract, with the brake shoes wedged out against two sides. The drums ovalize.
Old 08-13-2009, 04:05 PM   #9
Yaris Hilton
Smile
A car that's been left sitting outdoors undriven for a while will develop a rough patch of rust under the pads on the disks. That makes noise when you drive off, and makes the braking a bit rough till the disks get evenly polished again.
Kaminari body kit installed, drums painted (pic) BSPyaris Photo-Video-Media Gallery 36 01-01-2010 08:39 PM
sticker fun and painted drums staypuft Photo-Video-Media Gallery 4 08-05-2009 12:45 AM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Question about painting Calipers and Drums Arkhangel DIY / Maintenance / Service 12 04-27-2009 02:15 PM
rear drums the same on '01? cali yaris Performance Modifications 7 11-21-2008 10:46 AM
