Old 08-14-2009, 06:56 PM   #1
2009 vitz
Drives: 09 Vitz
RPM???
I don't know if this is right!?
I had a manual transmission, @ 4th gear doing 100km, is about 3600rpm. Same speed (100km) @ 5th gear about 3200rpm. Is that normal that the 4th & 5th gear r that close??? Just wondering!!
2009 vitz is offline   Reply With Quote
Old 08-14-2009, 11:09 PM   #2
2009 vitz
Drives: 09 Vitz
Can't see any info over there!?
Old 08-15-2009, 08:16 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
In this thread http://yarisworld.com/forums/showthread.php?t=5374 among the noise you can figure out that most people are seeing somewhere around 3000 RPM on the tach at 70 MPH.
Old 08-17-2009, 10:45 AM   #4
Revsson
I didn't see it either. What I would like to see is something like:
gear - mph - rpm
So, in first gear, going 15 mph, you are ____ rpm, and have that for every gear. I thought there was a posting once about the shift point speed in
mph and the corresponding rpm, but can't find it using the search function.
Old 08-17-2009, 08:53 PM   #5
2009 vitz: it is normal.
although, your eyes might be off, because 100kmh in 4th is 3000rpm and 5th is about 2700rpm.
plug in the gear ratio, for the 1nz-fe 5spd yaris.
First Gear Ratio (:1)
3.55
Second Gear Ratio (:1)
1.90
Third Gear Ratio (:1)
1.31
Fourth Gear Ratio (:1)
0.97
Fifth Gear Ratio (:1)
0.82
Reverse Ratio (:1)
3.25
Final Drive Axle Ratio (:1)
3.72
edit: this sheet is pretty much all good, except the final gear ratio, just modify as needed.
Gargling noise when RPM drops... ammophobia DIY / Maintenance / Service 8 09-28-2009 08:43 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 04:35 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
RPM problem. rwseattle Performance Modifications 7 04-03-2007 11:09 AM
