Old 08-17-2009, 01:31 PM   #1
doanutboi
doanutboi's Avatar
Drives: Yaris LB Coupe
tire sizes
hey what tire size do you guys recommend for me to get..its the 15" SSR MKII-Rs, 4x100, 15x6.5...
Team Praxis
...Setting the Standards...
doanutboi is offline   Reply With Quote
Old 08-21-2009, 08:22 PM   #2
fei
You can try 195/55/R15 or if you dont mind heavier tyres but more contact on the road, can get 205/55/R15 which im using now.
fei is offline   Reply With Quote
Old 08-21-2009, 10:24 PM   #3
doanutboi
doanutboi's Avatar
cool thanks, apreciate it
Team Praxis
Old 08-21-2009, 11:13 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
The offset / desired stance will determine what tire size you need . If the offset is higher than say +30 i'd say 205/55 or if the offset is lower than +20 go with a 195/55 for a slight tire stretch/ more fender clearence...
Old 08-22-2009, 04:01 AM   #5
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
yea itll be between a 195 or 205 for width but sidewall should always stay at 55 if you want to run close to oem sidewall sizing and keep your speedo relatively accurate
fyi:
16'' wheels have a 50 sidewall
17'' has a 45 sidewall
18'' has a 40
Old 08-22-2009, 08:32 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
fyi:
18'' has a 40
depends on the width of the tire..
205 55 15 and 225 50 15 are about the same height.
Old 08-22-2009, 01:17 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
15 x 6.5? Depends on the wheel offset and any suspension mods. Most common tyre sizes include: 205/50/15; 195/55/15; and 205/55/15.
Old 08-22-2009, 02:59 PM   #8
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
true i was referring to a 205.. which would be pointless on an 18
i really want to try out some 215/45s on my new 16s just to see what its like. never tried that out
Old 08-23-2009, 05:21 PM   #9
nerd_vitZ
Drives: 08 silver streak mica LB
it also depends on what youre looking for? looks, performance, daily driving? im going for looks on my 15x6.5's that are coming in and im thinking of going with 195/45/15.
nerd_vitZ is offline   Reply With Quote
Old 08-25-2009, 11:42 PM   #10
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Anyone here ever run a 15x6.5 wheel on 205/50 tire? What did you think? Once again, Im looking at getting some new wheels.
marlondog is offline   Reply With Quote
Old 08-28-2009, 07:25 PM   #11
fei
Im using a 15x6.5 wheel with tire size 205/55/R15 and they are perfect, i guess it should not be much difference from 205/50/R15, jus alittle more bumpy.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Replacement Tire Sizes Sailr303 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 06-10-2009 08:40 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
