Old 05-27-2009, 12:10 AM   #1
Sailr303
Drives: 2007 Yaris Sedan
Replacement Tire Sizes
I'm not looking to upgrade my wheels or do anything fancy but I have 185/60/15 tires on my 2007 sedan. This seems to be a difficult size to find as far as selection within brands. I've read all the stuff on the Tire Forum and I didn't understand very much of it. All I want to know is - what alternate sizes can I use on the same stock rims without performance problems. Can anyone help?
Thanks.
Sailr303 is offline   Reply With Quote
Old 05-27-2009, 12:14 AM   #2
supmet
Drives: 2007 4 Door Yaris
195/55/15 - won't rub - wider tire and shorter sidewall = slight improvement in handling and slight decrease in fuel efficiency
205/50/15 - might rub - moderate improvement in handling and medium decrease in fuel efficiency
Old 05-27-2009, 01:03 AM   #3
Morgan
Morgan's Avatar
Drives: 07 MM LB
I have 205/50/15 with the trd springs and dont rub... lots of things for sale in that size as well!
Old 05-27-2009, 07:59 AM   #4
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
this may be beneficial
http://www.miata.net/garage/tirecalc.html
I don't know why you can't find 185/60 though, that's a pretty generic size
to help you out, the first number is width, in millimeters, and the second number is height expressed in a percentage from the width-- the first number
is there a Sears or TireKingdom in your area? they could easily figure this all out for you
;D
Old 05-27-2009, 08:20 AM   #5
205/55R15 will NOT rub. But the OEM 15x5" might be a little too shallow to fit.
Old 05-27-2009, 09:07 AM   #6
scape
scape's Avatar
I thought the oem rim was 15x5.5
Old 05-27-2009, 10:33 AM   #7
b_hickman11
Drives: 08 Sedan
I bought these tires from tirerack in December and they are great! They also have 18 others to choose from.
http://www.tirerack.com/tires/tires....nSpeedRating=S
Old 05-27-2009, 12:10 PM   #8
maybe, but mine are 15x5 :( but even 5.5 is close fit for 205's.
i'd go with at least 15x6 for 205.
Old 05-27-2009, 11:37 PM   #9
Kal-El
Kal-El's Avatar
I have 215/50/15's on my stock steelies. Very slight rub on full turn.
They certainly look better when the tire flairs out a bit from the wheel covers (rather than the covers protruding beyond the 185's). Looks less cheap.
My next set will probably be 205/60/15's as I want a little more sidewall to fill out the fenders a bit more. Unless I can get my rims soon (17's).
Old 05-28-2009, 11:21 AM   #10
you are oversized... that results in a loss of power, and torque.. not to mention waste of gas. just becareful
Old 05-28-2009, 11:50 AM   #11
Kal-El
Kal-El's Avatar
Who me?
Definitely not over sized. All the people here that have 17" and even 18" are at least that wide and probably wider. Mine still look too small.
Plus, I average 40 mpg and power isn't diminished.
Old 05-28-2009, 03:29 PM   #12
Morgan
Morgan's Avatar
Drives: 07 MM LB
well 215 on a 5.5" wide wheel is pretty brave... I think my 205's look like they are about to pop off of my steelies but then again the azenis 615 run wide.
My stock wheels are 6" wide and the 205s look great
Old 05-28-2009, 05:36 PM   #13
41magmag41
Drives: Loaded 2007 mica silver sedan
How about 196/60 15's? These are also pretty generic and was wondering if anyone had any experience with this size.
41magmag41 is offline   Reply With Quote
Old 05-28-2009, 05:47 PM   #14
SailDesign
Drives: .
I have 215/55/15's on my stock steelies. Very slight rub on full turn.
<snip>
My next set will probably be 215/65/15's as I want a little more sidewall to fill out the fenders a bit more. Unless I can get my rims soon (17's).
the 215/55-15s are about 1/2" bigger (taller) than stock - not a real problem. The 215/65-15s, though, will be more than 2" taller, and will make your speedo read very wrong (apart from other considerations that may play here). You will be reading 70mph when in fact you will be doing 76.5 mph. The cops are not likely to think oversized tires are an excuse...
If you are rubbing "a bit" now, you will definitely rub with the 65 series.
Old 05-28-2009, 07:12 PM   #15
Who me?
Just what SailDesign said, a 225/35R18 is soooooooo not like 215/65R15. you have to diminish side walls if you want to go with bigger rims. You also have to go with less sidewall when going wider.....
I have 195/60R15 for the winter on 15x6.6" rims. no rubbing at all. Not to mention winter tires have thicker rubber... i have to jack the car much higher when trying to install them from 195/55R15. :D
At first, i was supposed to go with original 185/60R15, but then, the price was just irresistible, and i thought it would equal out the smaller diameter of my summer shoes lol.
Old 05-28-2009, 09:12 PM   #16
Franck_Qc
Franck_Qc's Avatar
Drives: 2008 Yaris RS
http://www.1010tires.com/TireSizeCalculator.asp
My tires (Toyo Proxes 4) are 205/55R15 and my rims (TSW Kyalami) 15"x 6" and +40 offset, don't rub. This is perfect !
Formerly 2008 Yaris RS Liftback 5 doors:
http://smg.photobucket.com/albums/v26/diofra/Yaris/
Now 2010 Matrix XR
http://smg.photobucket.com/albums/v2...2010%20Matrix/
Franck_Qc is offline   Reply With Quote
Old 05-28-2009, 11:34 PM   #17
Kal-El
Kal-El's Avatar
215 is width, not height. The 55 measurement is sidewall height.
So my 55's are lower than stock. If I were to go 215/65/15, they would be the same sidewall height as stock.
And as for the speedo, my smaller diameter didn't affect the speedo at all (I have a nav that reads the same exact speed).
Old 05-29-2009, 06:41 AM   #18
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yaris Wheel and Tire Guide:
http://www.yarisworld.com/forums/showthread.php?t=5021
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
OEM Tire Replacement mm34b Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 03-10-2009 08:02 PM
TIRE Replacement buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2009 12:52 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
