Old 08-25-2009, 04:27 PM   #1
SweetRS
Drives: 2006 Yaris Rs
Which coilover gives the biggest drop?
Which coilover gives the biggest drop? dont matter about comfort, and i plan on adjusting camber...
SweetRS is offline   Reply With Quote
Old 08-25-2009, 04:58 PM   #2
im all the way up on the rears of my megans and im dropped about 1.5"....could easily go down another 2-3"
front is about 1.5" drop too...likely could drop another 1.5"-2"
Old 08-29-2009, 05:48 PM   #3
jouna
jouna's Avatar
Drives: jdm yaris sedan
i like tein ...all my cars have them n are perfect
vvti bregao!
jouna is offline   Reply With Quote
Old 08-29-2009, 06:12 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
I know cusco rears can go an honest -6 to 7 inches lower than stock in the rear with-out the rear perches but the front only like 3 to 4 inches lower than stock all the way down .
Old 08-30-2009, 02:40 AM   #5
03Z33
03Z33's Avatar
Drives: TCR10
Without modifications and with the original parts that come with the kit the Silkroad coilover will allow you to run the lowest from the setups I've see. The spring rates are a bit higher than most other systems which will help keep you from bottoming out when you're super dumped and they come standard with adjustable sway bare links which are a must if you plan to be dumped and keep your sway bar.
The Megan is the only other kit I've seen that comes close to the Silkroad when it comes to lowering to the max. They don't come with the sway bar links and have slightly softer spring rates and softer shock dampening.
03Z33 is offline   Reply With Quote
Old 08-30-2009, 03:46 AM   #6
ddongbap
If you lower the height adjustment, and tension the crap out of the springs, I'm sure you can get em pretty low.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Big drop in FuelEcon Luna V 2.0 Fuel Economy Forum 16 07-31-2009 02:05 PM
Biggest BANG for the bucks? littlecarlove Performance Modifications 22 10-24-2006 02:48 PM
