Old 09-16-2009, 04:28 PM   #1
DevilGirl
Drives: 09 3dr LB MT
satellite radio with factory h/u
I want to keep the factory headunit. I'm looking to avoid the high price of having the dealer do the install. And I DO NOT want to put in a portable receiver. What I have found is this.
Will this work? Is there anything else I need? I'm racking my brain trying to figure out what all I need so I can install on the cheap.
Old 09-16-2009, 04:36 PM   #2
I don't think it will. It says that the HU must have a Sat button (which ours does not) and all of the vehicles listed use different HU's than ours.
Actually, I have the installation manual for the XM Satellite Radio kit for the 09+ Sedan and LB and it lists that same part number (86180-0W031) as being the included tuner. The other part necessary is the mounting kit (PT546-52096), which includes the cable, brackets, and the antenna.
Old 09-16-2009, 05:43 PM   #3
awdblazer
Drives: 1998 toyota rav4
does your factory radio have a aux in? if so you can use that
awdblazer is offline   Reply With Quote
Old 09-16-2009, 05:52 PM   #4
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
You can buy a factory Scion H/U with SAT capability very cheap, and its a direct bolt-in/plug-n-play setup. You do have to swap some wires to make the AUX jack work. Also, I think the 09 Yaris comes w/ a SAT button?? If so, find someone who's adding a fancy stereo and buy the original h/u from them.
Old 09-16-2009, 05:52 PM   #5
ozmdd
ozmdd's Avatar
Oops, just read your info. Does your 09 have a SAT button?
Old 09-16-2009, 06:27 PM   #6
Brian
Brian's Avatar
I bought my Sirius car kit (receiver, antenna, and dock) for $30 and use it with my factory head unit.
It has a built in FM transmitter or you can plug it in to the AUX jack.
Old 09-16-2009, 06:43 PM   #7
JCS_IMPORT_25
Drives: red vitz
yes they work great too thats what i got
JCS_IMPORT_25 is offline   Reply With Quote
Old 09-16-2009, 08:19 PM   #8
DevilGirl
Last I checked, my headunit does have a Satellite button on it. See the attached picture.
As far as the website not listing our car, well, I've found that a lot of sites do not recognize that the Yaris even exists.
So I'm trying to decipher as to what you say I need... Do I need this part and another? Or just the other?
Old 09-16-2009, 08:21 PM   #9
DevilGirl
I've done both the FM transmitter and the AUX jack connection route. Again, I repeat, I am trying to avoid that clutter of having way too many extra things around my dash, as well as the mass of visible wires, and the constant need for the use of the only power outlet in my car for the portable satellite radio units.
EDIT: I apologize if I come off sounding like I am attacking someone, it's been a long day, I'm frustrated, and I still have way to much to get done tonight.
Old 09-16-2009, 09:45 PM   #10
Mine has that as well (I just never noticed it)! As far as what you need, both the tuner and the "mounting kit" are required. The place you linked above doesn't show the kit, but doing a quick google brought up this one:
http://toyota.dealerfit.com/store/to...d385_29798.php
Attached is the complete installation guide so you can see what's involved in installing it.
XM SATELLITE RADIO.pdf
Old 09-17-2009, 08:04 AM   #11
DevilGirl
Ugh! I don't like their installation instructions. Way more than is needed...
Old 09-17-2009, 12:22 PM   #12
Agreed. The handy thing with the document is that it confirms that it can be done and confirms the part numbers that you need.
Old 09-17-2009, 01:37 PM   #13
DevilGirl
True. I wonder if there is anything stated somewhere for putting in Sirius rather than XM? I'm still up in the air as to which. And I think I found what is needed, and would be cheaper... But I'm prolly wrong.
this and this
Old 09-17-2009, 02:00 PM   #14
Yaris isn't listed in the compatibility list for the TOY-SC1.
Toyota has a Sirius option for Yaris: Tuner Assy: PT545-00080 and Mounting Kit: PT545-52091
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
FOR SALE: 2009 Factory Yaris CD/MP3 Radio - $60 including shipping 427chev Items for Sale by private party 8 05-09-2009 04:07 PM
Satellite Radio ToyotaTim In Car Entertainment + Electronics (audio / video / alarm) 38 03-13-2007 05:37 AM
picture of the back of the factory radio..? static808 In Car Entertainment + Electronics (audio / video / alarm) 3 11-10-2006 04:02 PM
