Old 09-22-2009, 03:03 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Display size
we had this one time in o/t section where everyone said what size there screens were.
I'm bringing this concern up over here before it ruins a thread about a members boosted s2000. anyways.
I'd just like to say I have a 22" (horizontal) screen I never figured out how to set up the display size correctly.
what I'm trying to say is this: my screen for Yarisworld is cut off
I get the upper task bar over to search and then I have to scroll over.
hope that makes sense.
is this an error on my part or YW?
Old 09-22-2009, 03:08 PM   #2
you should be able to increase your screen resolution and see the whole thing. I can change my monitor settings and duplicate what you see.
Mine is currently set to 1280 x 800
Old 09-22-2009, 03:14 PM   #3
Shroomster
Shroomster's Avatar
yeah....it's on my end you're right Garm.
I just adjusted it unfortunately I can't get a refresh rate higher than 75mhz oh well
Old 09-22-2009, 04:45 PM   #4
refresh rates I don't know much about. Is that a function of the graphics card or the monitor itself?
Old 09-22-2009, 06:15 PM   #5
Shroomster
Shroomster's Avatar
I thought it was the processor for the Tv (in this case at least I'm using a tv as the display)
I think the graphics card for the refresh rate of a monitor....but at any rate the card is refreshing the tv @ 75hz max on this display....I guess it's ok.
so bottom line is my display settings were out of whack not the websites hehe...
Old 09-22-2009, 07:57 PM   #6
wiliker
wiliker's Avatar
Drives: 2008 Yaris LB
1680x1050 is my setting on my 22" screen. Give that a shot.
wiliker is offline   Reply With Quote
Old 09-22-2009, 08:19 PM   #7
Shroomster
Shroomster's Avatar
I have it set to 1280x720
geez the closest I can get is 1600x900 damn...now everything is stretched crazy like lol. The icons are so small and far apart....
Old 09-23-2009, 07:13 AM   #8
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
I run a 22' monitor and keep mine at 1680x1050 refresh rate 60 hertz and I can see everything on every web site in correct symetry. Refresh rates are how often your graphics card or MB onboard graphics device sends a new signal your the pixels in your monitor. Refresh rates effect different monitors differently depending on the image latentcy (how long a pixel stays visable after it has been sent) Generally speaking the higher the refresh rate the better the image.
Bob Dog is offline   Reply With Quote
Old 09-23-2009, 08:28 AM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
@Shroomster: Please post the monitor model and I'll try to see if I can find some information on it. AFAIK you shouldn't set your refresh rate to anything higher than 60Hz if it's an LCD.
Old 09-23-2009, 12:37 PM   #10
Shroomster
Shroomster's Avatar
^^^really?
C-NET specs
Dynex website specs
Old 09-23-2009, 12:39 PM   #11
Bob Dog
Bob Dog's Avatar
Drives: 07 liftback
I should have said that TK, thank you.
These days if your computer recognizes your monitor, plug and play will usually block damaging refresh rates, but I don't know what it will do with a tv.
Old 09-23-2009, 01:05 PM   #12
tk-421
tk-421's Avatar
Drives: 5D-07-LB
It's quite possible you will be able to get other possible resolutions if you set the refresh rate to 60Hz. LCD doesn't refresh the way old CRTs do. See http://bit.ly/Hq4Sg for more info
Old 09-23-2009, 01:18 PM   #13
Bob Dog
Bob Dog's Avatar
Drives: 07 liftback
Yeah, set the refresh rate 60 and see what resolutions show up on the dropdown menu it might not work, but its a very good bet. If it doesn't work you might want to go to microsoft and poke around for a driver that will be updated and more suitable, depending on the age of your software and equipment.
Old 09-23-2009, 01:29 PM   #14
Shroomster
Shroomster's Avatar
well I updated my graphics driver (never updated it for 6 years). I have a plethora of usable screen sizes now. I think I'm going to stick with 1280x720 with 32 bit color @ 60 hz
everything shows up and no horizontal slide-bar anymore. thanks for the clarifications and help!
Old 09-23-2009, 01:30 PM   #15
Bob Dog
Bob Dog's Avatar
Drives: 07 liftback
excellent! and when I get the time I'm going to read up on lcd monitors so I can update my knowledge. go geeks go.
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 05:15 PM
