Old 10-12-2009, 10:27 AM   #1
headlight aim
has anyone w/ a hatchback adjusted their headlight aim? how do you go about doing it...? i read the toyota manual online, but going an looking at the headlight, do i just spin the white, plastic screw, or do i need to get around the back of the adjuster and turn the scew in there?!?
Old 10-12-2009, 10:45 AM   #2
ya, its totally different for the hatch....thanks though
Old 10-12-2009, 12:33 PM   #3
sex
sex's Avatar
Drives: 09 5DR
Page LI-102 of the 2007 Service Manual has the procedure
Old 10-12-2009, 12:37 PM   #4
i read the manual, but looking at it in real life, is the vertical aim adjusted by the white plastic screw, or do i need to get at the back of that adjuster?
Old 10-12-2009, 02:10 PM   #5
Snappy
Drives: 2 Yaris Hatchbacks
White screw. There is nothing additional to adjust at the rear of the lights.
For the US market, there doesn't seem to be any horizontal adjustment whatsoever, the horizontal adjuster screw is replaced with a snap-in post that is blank, and doesn't seem to be easily removable. Is Canada the same? The vertical screw is exposed, faces upwards, and is towards the inside (center of the car) of the headlamp assembly with the hood open.
Snappy is offline   Reply With Quote
Old 10-12-2009, 02:26 PM   #6
ya, just got back from doing it....its the white plastic screw...though counterclockwise seems to be down and clockwise is up
we'll see tonight if im still blinding people
Old 10-13-2009, 06:19 PM   #7
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
Where can I buy a controller for controlling a luminance output of HID kits cause I already aim the headlight low as posible and put a black vinyl eyelid on the top, I still get flash by other cars.
Red Horse is offline   Reply With Quote
Old 10-13-2009, 07:21 PM   #8
nemelek
DWEED
nemelek's Avatar
My headlights were way too high when I bought the car. During the day I parked near the garage and turned the white screw on top. I watched the light drop an inch or so. At night I parked on a flat side street and made the final adjustment. The lights are now where I liked them. I didn't have to adjust the side ways shine, just the height.
Old 10-13-2009, 07:47 PM   #9
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
there are no controllers that can dim HID kit's for cars. Light going upwards is the bottom reflector, not the top, so the eyelids wouldn't help you. Does your bulb have a shield that blocks light from reflecting off the bottom reflector bowl?
taKuto is offline   Reply With Quote
Old 10-14-2009, 12:01 AM   #10
Red Horse
Red Horse's Avatar
My blulb has a shiled but its not enough.
Old 12-19-2009, 02:09 PM   #11
djct_watt
Drives: 2010 NCP91 5spd
Did you guys have to remove the headlight to get at the left side adjuster? I can't seem to get around the fusebox/intake.
djct_watt is offline   Reply With Quote
Old 12-19-2009, 02:30 PM   #12
Lucas13
Drives: 07 Yaris LB
Did you install low beam only or mechanical BI-xenon?
I installed the Bi-xenon’s and the shield blocks the bottom portion of the reflectors perfectly making some adjustments on my bulbs by stretching the spring that goes by the solenoid that way the bulb stays out more and the shield covers much better I also adjusted the height a little bit lower and it seems to be o.k. since no one complaints, and my headlights aren’t pointing to the floor either.
Lucas13 is offline   Reply With Quote
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
how the he77 do you aim the headlight!! marcus General Yaris / Vitz Discussion 4 04-18-2007 06:58 PM
Headlight fog elsteverino889 Cosmetic Modifications (Exterior/Interior) 2 03-28-2007 06:38 AM
