Old 11-01-2009, 04:13 PM   #1
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
megan c bar help
i got a megan c bar here used but i don't know how to install it, does any of you have the manual or post some pics installed.
Thanks in advance
cruz-gsr is offline   Reply With Quote
Old 11-01-2009, 04:25 PM   #2
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Basically it installs using the bolts that are for the rear seat belts, you pull the panels in the back for the Cpillar, be careful theres about 5 plastic tabs that can be destroyed for each one, once you get this removed you will see a large bolt that holds in the Seat belt to the c pillar. Remove this bolt, save it.
Remove the end brackets from the Cpillar bar, then reinstall the bolts with the new cpillar bar brackets. Do the same for the other side, then install the Cpillar bar itself to the brackets, then align it all up and tighten, your done.
You can install the panels back, but you will need to get a circular cutting tool and cut a hole big enough to feed the brackets through so you can install the bar, then install the panels behind it. I did this, it looks alot better than have the panels off in the back.
Old 11-01-2009, 04:30 PM   #3
cruz-gsr
cruz-gsr's Avatar
i try that but the bar was kind of too long, can u snap a picture of your for me. please
Old 11-01-2009, 04:51 PM   #4
Sabretooth
37HSSV
Sabretooth's Avatar
The bar is completely adjustible, turn the actual bolts on the ends of the bar to make it longer or shorter, do it to both ends. It will take some playing with to get right.
Old 11-01-2009, 05:03 PM   #5
cruz-gsr
cruz-gsr's Avatar
i put it in all the way and still too long, maybe i put the backets the wrong way.
Old 11-01-2009, 05:07 PM   #6
Sabretooth
37HSSV
Sabretooth's Avatar
Maybe? I assume they only go one way, lol.
Just letting you know, you cant keep the actual seat belt parts for the rear, if you try and overlay the bracket on top, the bar would be too long.
Remove or simply tuck away the seat belts peices...
Old 11-01-2009, 05:26 PM   #7
cruz-gsr
cruz-gsr's Avatar
so, you don't use the rear seat belt, also do you use the spacer on the bolt.
Old 11-01-2009, 05:31 PM   #8
Sabretooth
37HSSV
Sabretooth's Avatar
Spacer? you talking about that flake thin metal spacer?
I used it, didnt bother it.
Ya, just remove the rear seat belts, or just position them where you can reinstall them later if you want.
If your talking about a thick spacer, mine didnt come with one, just
Cpillar - Bracket - Bolt from Seat Belts - Cpillar bar.
Old 11-01-2009, 05:38 PM   #9
cruz-gsr
cruz-gsr's Avatar
ok thanks bro
Old 11-02-2009, 12:32 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
that and your rear passengers should wear a helmet so they don't bump their heads.....
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
FS: Megan Rear Bar 33OH Items for Sale by private party 15 02-06-2009 10:44 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Megan front tie bar? AlphaFox Performance Modifications 39 08-08-2007 05:51 PM
