Old 11-04-2009, 06:31 PM   #1
XYaris
Drives: '09 Yaris LB
Penguin Spacer fitment Q...
Im running 205/40/17 on 17x7 rims (+40 offset) and Im lowered on TRD springs. Any fitment issues running 13mm Penguin spacers? What if I elect to use 205/45/17 in the future for more sidewall?
Thanks
XYaris is offline   Reply With Quote
Old 11-04-2009, 08:00 PM   #2
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
i have pretty much the same setup on DF210s i scrape a little bit, you should be fine, but i think some scraping is going to happen regardless anyways on your suspension setup too?
Old 11-04-2009, 09:07 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
Thanks
width causes rubbing, not height.
you'll rub on the passenger side first. yarii are crooked from the factory
Old 11-04-2009, 10:16 PM   #4
XYaris
So I will rub? What about 10mm? is this a definite thing either way with 205's?
Old 11-04-2009, 10:57 PM   #5
Penguin Garage
Penguin Garage's Avatar
if you're nervous about rubbing go with the 10mm.
Penguin Garage is offline   Reply With Quote
Old 11-04-2009, 11:07 PM   #6
XYaris
cool, thanks
Old 11-05-2009, 12:52 AM   #7
YarisSedan
Drives: 08 Yaris Sedan
I have 205/55/15s with trd springs and 10mm hub spacers i rub very very rarely. Just barely nicks the outer edge of the tire.
Old 11-16-2009, 12:43 AM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Bringing back an old thread... So the rear is about 3mm toward the passenger side?
I have another question. (I haven't installed spacers yet) If I can't get the toe perfectly
straight with the car, is it better to have the rear a bit toe-in or toe-out?
btw, when did Penguin Garage pull out of being a vendor?
I wanted to read some of the threads from PG, but it's no longer available.
Old 11-16-2009, 06:58 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
you need to talk to Yaris Bueller about his deletion of penguin garage's threads..
all PG parts are currently sold EXCLUSIVELY through www.microimageonline.com
and you want toe - in for safety, toe-out (or neutral toe actually) for improved turn-in.
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Free Penguin with spacer purchase ! Penguin Garage Penguin Garage 91 05-19-2010 07:05 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
