Old 12-06-2009, 05:22 PM   #1
YAR1S
YAR1S's Avatar
HID problem
hooked up all the wires....
lows and high beam dont work
parking lights come on instead???
I have the bi-xenon and I dont have DRL.
any help????
-Jen <3
Old 12-06-2009, 05:43 PM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
wow no pictures ? maybe someone can see if something out of place?
grounds are on metal? dont think thats anything to do with it but neverknow
pluged to power?
Originally Posted by sw07gt
Old 12-06-2009, 06:32 PM   #3
arunto
arunto's Avatar
Drives: 2008 Yaris LB
which kit did you get? I got the Bi-Xenon kit from microimage and it was plug and play. You might want to check your wiring though. The only thing I noticed is that my high beam indicator light doesn't work.
arunto is offline   Reply With Quote
Old 12-06-2009, 06:59 PM   #4
MGargano
Drives: 2009 Yaris Hatchback
PM CTScott for a fix to the hi-beam indicator not lighting up. I took my car to him and all was fixed in about 10 minutes. Something about the way the HIDs are wired causes it not to light, but the fix is very simple.
MGargano is offline   Reply With Quote
Old 12-06-2009, 08:46 PM   #5
YAR1S
YAR1S's Avatar
I got it fixed, the spot where I grounded one light wasnt working very well and I just had to sand the body paint down a bit to get a good connection! :)
-Jen <3
Old 12-06-2009, 09:43 PM   #6
JumpmanYaris
USAF_SrA_E-4
TOLD YOU SO!!! glad u got it done now pictures!!!!
HID Kit High-Beam Cluster Indicator Problem Split Cosmetic Modifications (Exterior/Interior) 21 07-24-2010 05:50 PM
2010 hid problem ketchup214 General Yaris / Vitz Discussion 10 11-22-2009 08:45 AM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
HID problem hex_yaris Cosmetic Modifications (Exterior/Interior) 3 01-02-2009 11:35 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
