Old 12-17-2009, 01:01 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Need URGENT HELP PLSS !!
hey guys
installed the K&N sri setup , as per the book , but car ideling very low and eventually cuts out , what is the porblem ?? all pipes are on and working
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 12-17-2009, 02:19 PM   #2
YAR1S
YAR1S's Avatar
the air sensor(I think thats what its called?) attached?
-Jen <3
Old 12-17-2009, 02:47 PM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
yeah , air sensor AKA mass airflow meter is on.
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 02:49 PM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
everything is on and plugged in as per instructions , im not sure of the air sensor is maybe faulty ? or if the vacume switch can cause the car to idle so low ?
come to think of it , with the OEM intake on the car did occilate quite hectically at times , like irregular ideling ,mmm , wonder what it can be ? maybe the intake made it more promenant
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 02:57 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
did you unplug the negative terminal completely for at least 15 minutes? When I installed my AEM I just unhooked the battery during the install and I was fine.
Old 12-17-2009, 03:02 PM   #6
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
yeah , i unplugged the terminal while installing , then reconnected when done , was off for approx 50min
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 03:06 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
Any chance the MAS was damaged? Any check engine lights?
Old 12-17-2009, 03:08 PM   #8
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
can the idle be set on the yaris ? maybe the dealer can set it with the ODB2 port tester ?
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 03:09 PM   #9
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i took the MAS out agian and checked , didnt see any damage , no engine check lights. scangauge also didnt pick anything up.
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 03:10 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
Honestly I don't know but if I had to guess I'd say no as this is something the ecu probably handles... But go ahead and correct me if I'm wrong.
Old 12-17-2009, 03:10 PM   #11
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i wonder if alot of driving will sort it out? idling is very low , approx 400rpm - 500rpm
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 03:19 PM   #12
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Strange. I just installed this unit without a problem. I wish I had something else to add ...
Old 12-17-2009, 03:34 PM   #13
Idle is not adjustable. It does sound like a MAF problem.
My Yaris always rpm hunted, I never liked that about it.
Old 12-17-2009, 03:41 PM   #14
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
yeah , could be MAF , i wonder if it isnt mabye dirty or somthing ? i did notice a little bit of black dirt on it , gave it a little wipe , but not properly. is a MAF very sensitive or a little robust ? how can you clean a MAF ?
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 03:43 PM   #15
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
try resetting ecu and cleaning maf
chongopants is offline   Reply With Quote
Old 12-17-2009, 03:48 PM   #16
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
already reset ECU , but havent cleaned the MAF , i did notice some black dirt on the one side of the sensor , how do i clean that off ? dont wanna break it
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 03:56 PM   #17
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i noticed in the K&N sri setup there is a small oval shaped piece of metal at an angle in the intake , why is it there ? to create wind turbulence ?
JDMtuner
www.jdmtuner.co.za
Old 12-17-2009, 08:59 PM   #18
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Now by cuts out do you mean the engine stalls completely? If it just oscillates a little on idle that is normal if you have an intake.
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
Yaris DOWN! Help! Urgent! mc_emily New YARIS Purchase Forum 8 09-04-2009 08:32 AM
EGR Error, Urgent Help Needed aliraja DIY / Maintenance / Service 27 04-29-2009 07:59 AM
how can u test a sub? URGENT Sway84 In Car Entertainment + Electronics (audio / video / alarm) 10 07-09-2007 02:16 PM
urgent info needed..(before going shopping) seanele Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-02-2007 10:07 PM
