#1 |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
Review of Tokico Blues with Tanabe NF springs
Hi all, I received the Blues from Garm on friday. Got them install on sat.
Below are my review of before & after with NF springs.NF springs with stock shock Comfort level: 9/10 Cornering feel: 6/10 Bouncy: 9/10 Stiffness: 4/10 Bottom out: Happen only when you going too fast over hump/bump. NF springs with Blues Comfort level: 7/10 Cornering feel: 9/10 Bouncy: 6/10 Stiffness: 9/10 Bottom out: Yet to hear any of them. Good NEWS for me!! Overall, the Blues is a very NICE & inexpensive upgrade over the coilover set-up if you're already lowered with after market springs. Now with the blues, i feel so much confident over my handling of the car. It give me much better feel of my car with the road. In the past with stock shock, while still in the mid of turn and if happen to have any slight bump, the car will just shift/bounce out a little and the feeling is pretty scary if the speed is fast enough. A must upgrade for anyone who want to improve the feel and add stablility to the ride while willing to lose out a little from the comfort zone. Thank you Garm for the great products!!!
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres Last edited by evo165; 12-20-2009 at 10:02 AM. |
I agree it is a nice ride. I already have Tanabe DF210 springs and just put in my Tokico blues yesterday with the 19mm Ultra Racing sway bar. And let me tell ya it handles nice and turns like its on rails, its crazy sexy cool.
#3 |
Nice, glad you like them! These little lightweight cars benefit so much from suspension upgrades!
#4 | |
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
#5 |
Alright guys, i managed to "reduce" the stiffness out from my car. Remember the earlier on "Rear free supension mod"?
I shifted up the pivot point of my rear suspension before i did my tokico blue as posted. By shifting the point up, i gain additional stiffness on my rear spring which i can gain slightly more responsive handling and the "extra" steering with the cost of losing the comfort.I just recently shifted back the pivot point to the stock configuration(lower point). And now BINGO!!!!! My ride feel less "stiff" on the rear for overall comfort and yet still can provide the "super glue" feeling round the corner!! I am falling in love with the BLUEs!!!!!!!!!
#6 | |
Apexing Egg!!
now, does spring preload effect the rear spring rate? i am not sure. you said you noted the rear felt more stiff, but is that an effect on the spring rate of compressing the rear spring or is that "feeling" from the change in suspension geometry? i am not really sure, id love to hear another opinion on this (ie. Loren, Tamago) so, i looked up this calculator for spring rate: http://www.engineersedge.com/spring_comp_calc_k.htm i changed only 1 variable, and that is the # of ACTIVE coils in the spring. i changed nothing else. using the defaults in the calculator, a change from 10 coils to 8 coils increased spring rate from 18k to 23k. so, what that tells me is this: if you take the DF210 rear spring and compress it (eliminating a certain amount of coils) by raising the rear suspension mounting point, you will increase the rear spring rate by doing so though reduction of the number of coils. how much? no idea, but it certainly SHOULD go up. another benefit to a free mod!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#7 | |
As mentioned, shifting up the pivot point will greatly compress the springs(higher spring rate) and at the same time, i strongly believe that we are playing with the rear suspension geometry as well. (Eg. roll center & anti squat thingy) Is anybody there who are good with car set-up pls enlighten us...
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
I do believe in the thread about the rear pivot point, the general consenus is that by shifting the rear pivot point to the higher slot, on a lowered yaris, that it helped put the rear geometry back closer to "stock" geometry levels. Helping correct the toe and such instead of being off a bit. Atleast that's how I understood it :)
#9 | |
![]() I will like to highlight on this "higher pivot point" suspension mod. To GAIN the best benefit of the upper pivot point, we will need to have shorter and stiffer springs for the rear suspension in order to enjoy the full benefit of "stock" geometry levels without causing the rear springs being compress "un-balance". I really don't feel comfortable seeing my rear Tanabe NF springs being compressed till most of my coils are touching each other and the springs are not standling vertically (|) instead they are being compress till like a "(" from the side view if we look carefully on inside of our rear wheel. Also, i move back to the lower stock pivot points to "reduce" the springs load effect so i could gain back some comfort.
| Tokico HP (blues) Shock/Strut driving impressions. | largeorangefont | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 09-09-2010 12:03 AM |
| Tokico Blues + TRD Springs &Sway Bar after 5k miles | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-17-2009 11:11 PM |
| Tanabe NF210 + Tokico vs. TRD springs and shocks | fmicle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 11-19-2009 03:42 PM |
| Tanabe NF210 vs Stock springs | tcpty | Yaris TS Talk | 15 | 11-12-2009 09:15 AM |
| TRD Springs Vs Tanabe DF210...The Title Bout | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 47 | 05-23-2009 10:02 PM |
