Old 12-20-2009, 09:56 PM   #1
Brentorius
Drives: 07 Mazda MX5 Copper Red
Fed up with rubbing... heres my plan
My current setup consists of OEM shocks with Tein S-tech springs, 17x7 +45 Team Dynamics with 205/40 tires, factory alignment. My ride height is 12.5" all around center of hub to fender.
I am getting rubbing in the front on almost every bump and it is really annoying. Turning at low speeds does not rub at all. The rear are fine even with a 12mm hub spacer.
My plan is to get an alignment with -2 camber and 0 toe in the front and from my calcs, I can move the upper outside edge of the tire ~.4" in. I have on the way: Tokico blues, TigerTec springs <a bit milder drop with a little higher spring rate in the front>, and a 23mm rear sway.
How does this sound? I have a lot of $$ invested in my rims and tires and want to keep them. The rims are really light <for 17's anyway>. I can switch to 195/45 tires and gain some width clearance there but lose some wheel well clearance <they are a little taller than the current tires>.
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 12-20-2009, 10:02 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
wonder why you are rubbing? I ran 205/40R17's +45 allday on DF's with no problems
and once you get the tigertec springs there will be no need for the extra - camber or smaller tires
Old 12-20-2009, 10:11 PM   #3
Brentorius
Maybe the teins sag? IIRC stock height was measured at 15" hub to fender which would indicate a 2.5" drop with the Teins...
Brent
Former Yaris Owner
Old 12-21-2009, 12:53 AM   #4
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
that's an insane drop, the teins are only supposed to do 1.5 on hatch and I think 2.0 on sedan.
RacerFreakXXX is offline   Reply With Quote
Old 12-21-2009, 02:15 AM   #5
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Not really an "insane drop" at all Imo and with the high offset on the wheels and not really wide tires at all all the "rubbing" is comming from the fender liners . Jack the car up , pull the stupid fender liners out and enjoy your car with no "rubbing" noises
Old 12-21-2009, 03:06 AM   #6
ddongbap
My signature is an insane drop.
Old 12-21-2009, 05:59 AM   #7
Brentorius
Yes the fender liners are interfering; I am not going to pull the liners because this is my daily...
Brent
Former Yaris Owner
Old 12-21-2009, 06:02 AM   #8
Brentorius
On the Tein website they are listed as 1.9 F&R for the 3-dr and 2.1/2.3 for the 5-dr
http://www.tein.com/price/toyota.html
Brent
Former Yaris Owner
Old 12-21-2009, 06:40 AM   #9
Black Yaris
der Zeck
the DF's settled to closer to a 3 inch drop, so I really do not see how the Teins are having a problem
Old 12-21-2009, 10:17 AM   #10
blacksandiegovitz
Drives: 08 Vitz
Well if you don't want to address you problem then why did you ask the question
Fyi I don't see what not having fender liners has to do with your car being daily driven , I pulled my fender liners last year , slammed my ride on cusco coilovers and have not had a problem yet...and my car is daily driven
Old 12-21-2009, 10:46 AM   #11
+1 no liners, daily driver here too.
But if he doesn't want to, that's ok. Do the springs and shocks first, then see if you have rubbing and need to do negative camber in the front. (OP mentioned the camber first, but I think that is out of order since he already has parts on the way).
You can also TRIM the liners only where they rub, keeping the rest intact.
Old 12-21-2009, 11:21 AM   #12
Brentorius
On previous cars, removing fender liners led debris and water in the engine bay or exposing wires and electronics to the elements. Maybe this is not a problem with the Yaris so i will consider it. More than 1 way of doing things and I just wanted to get some opinions.
Thanks for everyones input. I'll update when the new parts are installed.
Brent
Former Yaris Owner
Old 12-21-2009, 02:18 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
the camber will help a lot. and -2.0 isn't really that much, honestly. i've daily driven on -3.0 and flipped the tires once in their life cycle.. not too bad, and it sure turns nicely :D
Old 12-22-2009, 10:28 AM   #14
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Just change out the shocks! I had the same problem. Those Tokico'z will do the job, and you won't need to change out everything. Put that extra cash away for a rainy day!
marlondog is offline   Reply With Quote
Old 12-22-2009, 11:59 AM   #15
Brentorius
I trimmed the front fender liners a bit where they were rubbing. There is still rubbing, but not as frequent.
@marlondog I am going to try the tokico blues/tein springs first with slightly aggressive alignment (-1.5 camber 0 toe) and see how that goes. I really like the stance with the teins! If not, I am going to go with the slightly higher TigerTecs.
Brent
Former Yaris Owner
Old 12-22-2009, 12:18 PM   #16
yarr_is
Drives: yaris
You can always ... roll the fenders and never worry about rubbing anymore. Even though you go wide on wheels =3
Partially Sponsored by:
Tanabe USA
yarr_is is offline   Reply With Quote
Old 12-22-2009, 12:59 PM   #17
marlondog
marlondog's Avatar
Keep it Teinsta! I swithched to NF's for 2 weeks, but missed my green springs so bad. I put them back on, and the rub was gone.
Old 12-22-2009, 02:10 PM   #18
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
im running 215/45/17, rolled the rear fenders and still rubbing, i think its agains the screws holding the rear bumper, only rubs on deep dips, got
TRD's on the way hopefully will solve the issue
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
Rubbing botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-06-2009 03:32 PM
Dealing With Rubbing nqd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 42 04-24-2009 01:56 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 05:09 PM
