Old 01-01-2010, 09:45 AM   #1
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
what are centric rings
I am looking to buy a set of wheel for my yaris LB in the spring.Some says they come with centric rings is this something to stay away from does this mean they are cheap wheels Thanks!
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-01-2010, 01:03 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Centric ring centers the rim to the hub bore. Some rims are not hub centric and this ring helps fill in the space. Otherwise its possible to put your rims on crooked onto the hub and you will get horrible vibration at high speeds. Eventually this will slot out the lugnut holes and worse case scenario the wheel would fall off.
Only other alternative is to get lugcentric lugnuts. They are tapered so they center the wheel that way as a alternative.
Old 01-01-2010, 02:16 PM   #3
http://www.microimageonline.com/foru...tle=hubcentric
Old 01-02-2010, 08:57 PM   #4
gonzo452001
Thanks
oem style foglights
Scan GaugeII
Old 01-21-2010, 01:52 PM   #5
flyguyskt
Drives: white hatch
you want hub centric ring or wheels. period. helps with balance at speed
flyguyskt is offline   Reply With Quote
My trim rings and center caps..... RedRide Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 11-05-2017 06:42 AM
A/C Vent Trim Rings TinyGiant Cosmetic Modifications (Exterior/Interior) 25 06-19-2010 04:09 PM
Completed. Gauges set up WITH rings. PETERPOOP Cosmetic Modifications (Exterior/Interior) 33 10-03-2009 02:35 AM
Hub Centric Rings HTM Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2009 05:04 PM
hub centric rings & Exel wheel - what size Mead Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-02-2007 02:02 PM
