Old 01-13-2010, 05:08 PM   #1
goku87
goku87's Avatar
Drives: Black HB
LED Door Sills
http://www.youtube.com/watch?v=pf9eBiOdvas
If only they made them for coupe...
Old 01-13-2010, 10:18 PM   #2
IsLNdbOi
IsLNdbOi's Avatar
Which model is the coupe? The hatchback or the sedan?
Old 01-13-2010, 10:40 PM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
LB
Originally Posted by sw07gt
Old 01-13-2010, 10:44 PM   #4
yaris2010RS
yaris2010RS's Avatar
so that wont fit the 2010 LB?
Old 01-13-2010, 10:45 PM   #5
IsLNdbOi
IsLNdbOi's Avatar
As far as I know, these do fit the LB (the 5-door one at least):
http://shop.microimageonline.com/pro...4&categoryId=5
Old 01-13-2010, 11:29 PM   #6
goku87
goku87's Avatar
Drives: Black HB
ha, i didnt even see that! lol
Old 01-15-2010, 12:27 PM   #7
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
Yes, they fit both the 5-door and sedan, not the 3-door.
kargoboy is offline   Reply With Quote
Old 01-16-2010, 02:51 AM   #8
IsLNdbOi
IsLNdbOi's Avatar
So there are four pieces right? One for each door?
Old 01-16-2010, 03:13 AM   #9
goku87
goku87's Avatar
Drives: Black HB
That's the way it seems. I wonder what it would look like if you stuck the two front ones in a 3 door lol.
Old 01-16-2010, 04:39 AM   #10
r3b3l
r3b3l's Avatar
Drives: 2010 Yaris 3dr liftback
I am sure it would work I am about to try it on my LB.
r3b3l is offline   Reply With Quote
Old 01-16-2010, 04:45 AM   #11
IsLNdbOi
IsLNdbOi's Avatar
Is there any way to set the color and leave it on one color? I'd want it white all the time.
Old 01-16-2010, 05:39 AM   #12
goku87
goku87's Avatar
Drives: Black HB
PM Garm, he's got them on his site.
Old 01-16-2010, 10:42 PM   #13
kargoboy
kargoboy's Avatar
You can't set the color unless you swap the LEDs and I don't know where
you could buy replacements.
Yeah, Garm has them, they are the same OEM accessories I used to sell.
Old 01-17-2010, 12:56 AM   #14
IsLNdbOi
IsLNdbOi's Avatar
Originally Posted by kargoboy View Post
You can't set the color unless you swap the LEDs and I don't know where you could buy replacements.
That's a shame. The cycling colors looks cheesy / tacky.
Old 01-17-2010, 12:59 AM   #15
r3b3l
r3b3l's Avatar
Im sure you can source the bulb and replace them, just have to get a set and look for the bulbs.
Old 01-25-2010, 02:39 PM   #16
GeneralDon7
Drives: Yaris Sedan
Yea these are the exact same ones I bought from you kargoboy when you had them. When it finally gets warmer out I'm gonna attempt to connect them to my dome light. The only issue I have(and it could be from a wrong installation), but they rub against the bottom of the door, especially on the rear doors, which are harder to close now. Not sure if anyone else has run into this who has them, but wouldnt mind a suggestion.
GeneralDon7 is offline   Reply With Quote
Old 09-06-2011, 08:44 PM   #17
skeck
keckbot
skeck's Avatar
Drives: 2007 Blazin' Blue Liftback
Bought a set of these off of ebay that are blue led to match my blazing blue yaris. Just got done hooking them up using the DIY on this site. They work perfectly...go out when the dome light turns off when the doors are closed. Although I have to admit, after I had installed one, I was glad I had waited to install the other, because I wasn't sure if they were really turning off when the door is closed and well... when the door is closed you can't see them of course :P so it did make it interesting for a minute. Well worth the $50 investment.
skeck is offline   Reply With Quote
Old 09-09-2011, 11:23 AM   #18
yaris2010RS
pics or it didnt happen
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 05-31-2012 11:58 PM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
FS: JDM Modellist II Front bumper & JDM LED tails DKN-YARIS Items for Sale by private party 7 11-09-2008 01:10 AM
