Old 01-24-2010, 12:13 AM   #1
tkalfaoglu
Drives: Yaris 2005
Installing a central door lock.. how?
Hi there. Upon returning from shopping, I noticed that I only had the key to my yaris -- not the alarm unlock button :) It somehow got torn from the keychain when I was sticking it in my jeans pocket..
(So I just unlocked the car, alarm blaring, and disconnected the alarm. How easy it was!)
Worse, the spare button was also nowhere to be found at home. It turns out if you do NOT have either remote, you have to replace the main unit as the unlock combination cannot be found.
The alarm unit also had a handy feature: Central door lock/unlock.
I don't care about the alarm, but the central lock/unlock was useful.
So I went to ebay and found something compatible..
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Unfortunately it is not pin compatible with the old alarm (which had come factory installed with the car). So I have to match the wires one by one.
I disconnected the old alarm+central lock unit, and tried to install the new thing.
However, the instructions are really lame. I has different wiring charts for "car alarm out port", "negative trigger", "positive trigger", "positive-negative trigger" and "pneumatic lock" ..
I have no idea how to wire this thing - can anyone shed some light?
Many thanks! -turgut
tkalfaoglu is offline   Reply With Quote
Old 01-25-2010, 02:28 PM   #2
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
have you tried taking a car place
maybe they can install it for you
for a small fee.
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 01-26-2010, 01:51 PM   #3
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
Ummm, I'm pretty sure you can teach your OEM VIP Toyota alarm system to work with any OEM replacement remote.
You need to look harder for the steps to program in a new remote.
You shouldn't need to replace your alarm.
Reeves360 is offline   Reply With Quote
Old 02-05-2010, 03:19 AM   #4
tkalfaoglu
Drives: Yaris 2005
Toyota: I think I might just do that tomorrow!
Reeves: Many thanks - so you mean I should take apart a new remote, try the different combinations inside to see if one works with Yaris's old alarm?
Many thanks, -turgut
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Need help installing springs Deltasix DIY / Maintenance / Service 11 05-03-2009 04:36 PM
Toyota Vitz problem with central locking cmica General Yaris / Vitz Discussion 1 04-27-2009 03:16 PM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
Cierre Central abdiel hiram Central and South America 2 04-17-2007 06:05 PM
