Old 02-13-2010, 12:37 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
Timing Chain
I have the Hatchback Yaris 2007. I believe I read it has a timing chain and not a belt is this true? I do not have the manual bought car used.
I have 81,000 miles and have never been to dealer as I do my own maintenance.
Old 02-13-2010, 12:53 PM   #2
kou
Drives: 08 lb
Yes it has a timing chain.
Old 02-13-2010, 01:18 PM   #3
bankrobber
when does it need to be changed 150,000?
Old 02-13-2010, 02:48 PM   #4
90tsi
90tsi's Avatar
Drives: 09 yaris
i know on other older vehicles it used to be 100k to 120k but im not sure about what toyota calls for now.
90tsi is offline   Reply With Quote
Old 02-13-2010, 04:33 PM   #5
DerFlosser
DerFlosser's Avatar
never unless the car is abused. Maybe a tensioner or rail but the chain should be good.
DerFlosser is offline   Reply With Quote
Old 02-13-2010, 05:33 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
There is no recommended change interval.
Old 02-13-2010, 06:59 PM   #7
bankrobber
OK,thaks for the info. That will save on maintanance costs
Old 02-13-2010, 07:36 PM   #8
severous01
if you're having running problems you can check the tension and slack in the chain by removing the cover, setting to TDC and marking the pulley. move engine backwards and see how far the pulley moves until the cam moves. any more than about 6-8* and i'd have a problem with it.
but then again, it depends on how bad car's running, cost of chain, and how long it's gonna take me to change it.
Engine Type lily General Yaris / Vitz Discussion 34 10-09-2009 01:23 PM
australian vs american models: timing chain hoobyjuice DIY / Maintenance / Service 3 06-16-2009 09:25 AM
wtf?! timing chain cover split?! jeff69dini DIY / Maintenance / Service 9 08-01-2007 12:11 PM
Does the Yaris' engine have a timing chain or belt? grampi General Yaris / Vitz Discussion 8 05-12-2007 03:59 AM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 11:50 AM
