Old 02-16-2010, 10:26 PM   #1
Hard_Yaris
Drives: 07 Yaris
Question Any info onThrottle Body Cleaning ???
I've never done this myself, and would like to know the proper way to do it since Toyota stealer-ships charge a good amount for what i can only see as something that's fairly easy to do.
Any one want to take on a photo DIY for Throttle Body Cleaning?
or at least a couple tips on what to touch and what not to touch when cleaning.
Hard_Yaris is offline   Reply With Quote
Old 02-16-2010, 10:43 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Step 1 remove air intake assembly from throttle body
Step 2 spray throttle body assembly with carb cleaner
Step 3 whipe with rag
Step 4 put back together
Old 02-16-2010, 10:46 PM   #3
YarisSedan
foIf there is a big interst i might take pics and make a diy on my day off this thursday im curiouse how my own throttle body looks at 25k miles. Ill post a DIY on how to do seafoam treatment of intake manifold too.
Which some shops call fuel injuection or throttle body cleaning. Even though thats not entirely what it is.
Old 02-16-2010, 11:42 PM   #4
Hard_Yaris
Drives: 07 Yaris
so It is easy to do.
Any specific cleaners? Is Carb Cleaner alcohol?
Yea the Sea Foam thing sounds cool... would you have to change the oil after that kind of treatment?
Old 02-17-2010, 05:08 AM   #5
kazama82
Drives: VIOS
we need to open the butterfly valve right?..or just spray with the valve closed?
kazama82 is offline   Reply With Quote
Old 02-17-2010, 05:45 AM   #6
1NZYaris1
1NZYaris1's Avatar
Once you have cleaned it , install a catch can on the engine breathers
your car will thank you for it .
And so will your wallet
Old 02-17-2010, 01:26 PM   #7
Hard_Yaris
Drives: 07 Yaris
Yes I'm wondering the same thing... How delicate is this butterfly valve, and should i touch it?
Old 02-17-2010, 01:49 PM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
They're typically quite sturdy, but I've never seen the one on the Yaris. When I clean the TB on my Jeep I either manually open the valve with my finger or use the mechanical lever on the side of the TB.
Old 02-17-2010, 06:42 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
would love to see a step by step for the seafoam the intake manifold. I've only done the seafoam on old carburetor type engines. I was thinking i'd foam my yaris when I get in the neighborhood of 60,000 - 80,000 miles. At 42,000 right now.
Old 02-17-2010, 07:04 PM   #10
Hard_Yaris
Drives: 07 Yaris
Yea I would love to see a Sea-Foam DIY.
So when cleaning the Drive By Wire Throttle Body, is there a way to move the butterfly other than with your finger?
Also should you start the motor without the airbox in place like the old carburetors?
I took my air box off and had a hard time moving the butterfly so i could not clean my throttle body as good as i would like.
Old 02-17-2010, 07:20 PM   #11
kazama82
Drives: VIOS
ok..i had a fren done on his yaris sedan..
what to do, turn your key to ignition on (dont start your car!!), asked a second person or put a brick on the accelerator paddle..then your butterfly valve will open..
we have to do so as our car is DBW-Drive by wire..for drive by cable, no need to turn your key to ignition, just press the paddle to the metal..:)
Old 02-17-2010, 08:42 PM   #12
severous01
you can take off the hose to the brake booster or any other thing that the intake has vacuum on...slowly pour the seafoam in there or buy a metering device from the auto store.
the metering device has a fitting that slips into hoses and is like an orifice and slowly allows product to mix with air and still maintain vacuum. it looks like a stepped drill bit or speed bit but it's plastic or rubber.
or, there's another that's pressurized and hooks up to an air hose and you put it in front of the throttle, after the MAF and it'll clean the throttle as well as the idle air controller.
Old 02-18-2010, 06:48 AM   #13
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Usually throttle body cleaning if its ever done at all is carried out on extremely high mileage vehicles ,what symptoms are you getting that your 07 car needs a throttle body cleaning?
Old 02-18-2010, 10:53 AM   #14
Hard_Yaris
Drives: 07 Yaris
My millage is @ 87,000km in the last couple months there has been some sluggish performance and i was getting a 100 more km per tank a few months ago.
Old 02-18-2010, 01:53 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
I don't notice lost performance but can confirm that winter temperatures and possibly winter blend fuel steal nearly 100 kl. per tank from my sedan (Southern Ontario). I go from 6+ commutes to 5+ commutes per tank come winter.
Old 02-18-2010, 01:57 PM   #16
Hard_Yaris
Drives: 07 Yaris
Yea and the softer winter tires eat a lot of fuel. Good to hear im not the only one with this problem.
Going to check the spark plugs today... maybe they are really dirty.
Old 02-18-2010, 02:41 PM   #17
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
Preventative maintenance. Why wait until it's really bad?
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 02-19-2010, 12:34 PM   #18
Hard_Yaris
Drives: 07 Yaris
Cleaned the throttle body and the spark plugs yesterday... She starts way quicker with fewer turnovers.
I need a body kit LA Yaris California 1 11-06-2009 01:26 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
