Old 02-17-2010, 06:46 PM   #1
vhicke
Drives: yaris
Adding aux to cd/mp3 factory
Hi here is a pic of the back of my toyota yaris 2008 sedan deck....I was wondering if i could add a aux cable to this and run to the real aux spot next to the ebrake.....
vhicke is offline   Reply With Quote
Old 02-17-2010, 08:39 PM   #2
Yes. The Aux cable connects to the second connector from the left.
Old 02-17-2010, 09:36 PM   #3
vhicke
Drives: yaris
Do you know where i can find one....My setup does not have the wiring done.
Old 02-17-2010, 09:56 PM   #4
A junkyard is your best bet. The AUX cable can not be purchased from Toyota, as it is part of a larger harness. I sold the one from Crashy (which I separated from the rest of the harness). I also grabbed one (and sold it) from a junkyard, where they gave me free reign to pull cables and connectors off a wrecked Yaris.
Old 02-18-2010, 03:05 PM   #5
vhicke
Drives: yaris
Here is what i have in the back of radio hooked up.....I went to dealer and he says there should be a aux wire run throw the dash...I found something on the right side of the console it is a 4 pin with (2 red,1 green,1 gray) wires..Not sure if this is for the aux...
Old 02-18-2010, 03:22 PM   #6
That sounds correct for a sedan. The EWD shows connector D75 (the connector for the console side of the aux cable) as being a 4 pin connector with green, red, gray, red.
Seeing the picture of that radio though, if I remember correctly that particular radio doesn't support the Aux mode.
Old 02-18-2010, 03:37 PM   #7
bitz767
Drives: 2010 Black Manual 3 door
http://www.yarisworld.com/forums/showthread.php?t=25840
ive got a head unit for sale that supports the aux input, it came from a 2010 liftback, but it should work in the sedan correct?
bitz767 is offline   Reply With Quote
Old 02-18-2010, 04:47 PM   #8
vhicke
Drives: yaris
So what your saying that they did the wiring in the car but the radio does not do aux.....Toyota always does something stupid like this.....So should not waste my money on aux plug....I just had the toyota dealer order for me...But have not paid....So i should just get a new deck...
Old 03-04-2010, 10:25 PM   #9
hhhieu
Drives: Yaris Sedan 2008
Adding aux to in dash player
Can anybody explains what D75 connector use for?
Anh what is Stereo jack adaptor?
Thank you so much.
hhhieu is offline   Reply With Quote
Old 03-04-2010, 10:32 PM   #10
D75 is the connector that plugs into the AUX jack (otherwise known as the stereo jack adapter).
Old 03-04-2010, 11:33 PM   #11
hhhieu
Thank you for your help.
My car names VIOS, it looks like as Yaris sadan and does not have this jack and also no dics aux control.
So, can I make an aux jack for my Ipod?
Old 03-05-2010, 07:46 AM   #12
From what others have found with your radio, it is best to change the radio to an aftermarket one to gain an aux jack.
Old 03-06-2010, 04:10 AM   #13
hhhieu
Thanks.
Old 03-07-2010, 08:09 PM   #14
vhicke
Drives: yaris
I changed my factory deck with a new aftermarket and it sounds much better already.
Old 08-03-2010, 12:48 AM   #15
canfoo07rs
Drives: 2007 RS
I'm wondering if it works with "track 99"...
canfoo07rs is offline   Reply With Quote
FOR SALE: 2009 Factory Yaris CD/MP3 Radio - $60 including shipping 427chev Items for Sale by private party 8 05-09-2009 04:07 PM
diy factory aux location with aftermarked hu battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 0 10-28-2008 10:38 PM
Factory AUX Jack ojo In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2007 09:41 PM
