Old 03-15-2010, 03:57 PM   #1
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Not so spontaneous, intended acceleration
OK. So all my previous cars have had carburetors... with multiple barrels which operate in a tiered fashion as you depress the pedal farther. On my old cars with Rochester Quadrajets, I've always been slightly annoyed that it seems you have to push the pedal way down before you get a reasonable percentage of total engine power.
With the Yaris, I have the opposite complaint. A tiny depression of the accelerator results in a large fraction of the engine's capacity being called to bear. And the automatic transmission also acts as though I've indicated that I want to really fly.
Now, with the drive by wire throttle that we have, the engineers could have specified any curve that they wanted. I wonder why they went with this? And what is "this"? Is the throttle rotation, in degrees, linear with respect to the depression of the pedal? Is the cross-sectional area exposed by the throttle plate linear with pedal depression? Or is the curve completely different? And if so, why was that curve chosen?
Or am I the only one who would prefer a more "laid back" calibration?
-Steve
sbergman27 is offline   Reply With Quote
Old 03-15-2010, 04:23 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
It's a "learning" system. You may want to try resetting it to default so that it can learn YOUR driving habits.
The throttle pedal is definitely not linear. Think of it as a "demand" pedal. Where you place your foot and/or how quickly you move it are the inputs that the ECU uses to assess what you want it to do. It then uses that input and many others to determine how much to open the throttle, how to set the valve timing and ignition timing, whether to go rich (open loop) or use the O2 feedback to keep the mixture stoich, etc.
Most people complain about the opposite problem, the DBW system is not sensitive enough. And maybe that's what you're feeling? It's not sensitive to a small input, so you give it a larger one... which it then responds to.
Give it time, it should learn you and you will learn it... you'll get used to it.
Old 03-15-2010, 04:40 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I've noticed a trend in recent years to make throttles very quick responding in the first bit of travel. It's a cheap way to make drivers think a car is very powerful and speedy. "It wants to leap ahead when I barely give it the gas!" If they have to push the pedal halfway down to get the same response, average drivers will conclude the car lacks power.
Old 03-15-2010, 04:49 PM   #4
sbergman27
sbergman27's Avatar
My accelerator pedal is heuristic!?!?!?!?!?!?
Oh my. I was not expecting that.
What's the easiest way to go back to the defaults? I've driven 2-1/2 weeks and about 6,000 miles (yeah, I drive a lot) and have not noticed any change in its behavior.
-Steve
Edit: The *very* first bit of pedal travel does not seem to get any response at all, so I push it a little farther (not much) until I do get a response. When it kicks in, that's when it seems overly sensitive. Is that what you are referring to?
Old 03-15-2010, 04:57 PM   #5
Yaris Hilton
Smile
The only learning behavior I've noticed is in transmission shift points. It trains very quickly, usually in a day's driving. No special action is needed for resetting, it adjusts to your driving style as you go. Thrash it and it'll wind up farther before shifting and downshift quicker. Drive it like a hypermiler and it'll lug along shifting when it really has to.
Old 03-15-2010, 04:58 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
-Steve
Disconnect the battery for a period of time (just how long I'm not sure as I've seen many different values mentioned.)
FWIW - Mine is a manual and I find just the opposite in that I have to goose it a bit to avoid stalling when letting the clutch out. I've considered doing the reset and stomping on it for a while to see if the ECU adapts to the new style. Let us know how your experiment works out.
Old 03-15-2010, 05:04 PM   #7
Loren
What?
Loren's Avatar
If you've driven 6k in 2.5 weeks, it's probably 95% highway miles, and the ECU isn't "learning" very much. A week of stop-and-go "city" driving would really teach it something.
I'm pretty sure that disconnecting the battery for a bit will clear the short term ECU settings. Seems to work well for people who are doing things like swapping headers and such to get the car to re-learn it's new "self".
You know that the Yaris factory service manual is available online, right? You can read and learn a lot from them.
Old 03-15-2010, 05:12 PM   #8
sbergman27
sbergman27's Avatar
At least. And my Yaris experience has been a bit of an unexpected whirlwind affair. (Impulse buy, in a way.) I'm so used to knowing all the intimate details about my cars like the back of my hand... but only determined that the transmission is a sealed unit, using Toyota WS fluid, earlier today. The proper antifreeze is a non-silicate, hybrid organic acid formulation. (Not to be confused with a hybrid organic acid formulation with silicates, or a non-hybrid organic acid formulation with or without silicates.) The list of surprises goes on. What an interesting adventure this is turning out to be.
Perhaps I should change my name to Alice, for now?
And no. I didn't realize that the FSM was available online. I'll have a look. I'm sure that it will be most interesting. Curiouser and curiouser, said Alice...
-Steve
Old 03-16-2010, 02:42 PM   #9
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
-Steve
I have the same issue and have reset my car multiple times. Also pushing down on the pedal feels like there is almost no resistance when compared to a pedal in an older car.
I'm assuming they made it this way on purpose because they felt people would over rev the car when switching from normal gas pedals.
Reeves360 is offline   Reply With Quote
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Did Toyota Prius Driver Fake Unintended Acceleration? JBougie Off-topic / Other Cars / Everything else Discussions 33 03-15-2010 11:24 AM
Yaris Acceleration Decays cheche DIY / Maintenance / Service 0 07-08-2009 08:34 AM
stick vs. auto acceleration abcando General Yaris / Vitz Discussion 36 04-08-2009 08:06 AM
more acceleration with smaller tire diameter? Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-28-2009 07:50 AM
