Old 03-16-2010, 06:30 PM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
15x8 end all questions
So I know this is a much debated topic and I have searched and Ive seen people running some low offset on their yarii, ive also seen a lot of people flame it. I am trying to get on more of an agreement. Im trying to pick up a set of xxr 002 wheels in 15x8 +0. I want to know will they fit. Some say there will be rubbing issues and others say its fine. Im fine with a tiny bit of rubbing at full turn because I rarely do that on the street and I plan on setting my camber to negative once I finish my suspension. Im going to be putting tein s-techs on with tokico blues so the drop will be around 2 in.
Im going for the flush look and I just want to know is 15x8 +0 doable or will it not fit?
Old 03-16-2010, 06:50 PM   #2
coffiend
coffiend's Avatar
Drives: 08 Black LB
I'm on 15x7 xxr 513 : tein s tech : 185 55 15 tires and the rubbing wasn't as bad as I thought it was going to be. I imagine that when I get Canbered there will be no rubbing.
If I had to guess, I'd say you could pull it off with some camber and rolled fenders still with SOME rubbing.
Might be annoying, but it sure would look pretty.
Old 03-16-2010, 06:58 PM   #3
1.5
Form>Function
1.5's Avatar
im so tempted to experiment anyways lol.
Old 03-16-2010, 07:13 PM   #4
Mister Z
Drives: 08 Yaris HB
I think it would also depend on the tire size you run.
Mister Z is offline   Reply With Quote
Old 03-16-2010, 07:19 PM   #5
1.5
Form>Function
1.5's Avatar
im gonna run something thin and really skinny for a stretched look.
Old 03-17-2010, 12:15 AM   #6
coffiend
coffiend's Avatar
Drives: 08 Black LB
If you have the $$$ and time to expirement go for it man! It would look really nice.
The one thing that I want to point out is that even though you have the s techs, a really short sidewall on 15s might leave you with a not-so-hot wheel gap. I have a little more space than I would like ideally on mine bit can't afford coilover so I'm just going to have to suck it up till I can afford some.... Just a little food for thought ;)
anyways, I'm excited to see whatever you end up doing.
Old 03-17-2010, 12:25 AM   #7
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
no matter how perfect your offset is, you will not sit flush on stechs purely because they dont go low enough
i just installed a set on my sedan hoping to cut my wheel gap to nothing but i still have a little over a one finger gap. flush is pretty much no wheel gap so im prob gonna end up switching out my suspension again to coilovers to go lower.
the stechs are way lower than the trds i just had but still not low enough for my taste
Old 03-17-2010, 12:51 AM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You will sit flush, but rubbing will be inevitable if you want the flush look.
As for tires - if you run 195/45/15 which is the lowest profile you can get, it will poke a little.
You can stretch 175/50/15 or 165/50/15, but I wouldn't recommend 165, since its width is less than stock.
Old 03-17-2010, 02:23 AM   #9
1.5
Form>Function
1.5's Avatar
I feel like the s-techs would be perfect cuz it will look almost flush but I wont be too low to worry about hard rubbing.
Old 03-17-2010, 02:32 AM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
a wheel with 15x8 +0 offset will poke in the front, poke in the back.
If you look at BrazdonW's car, he has 15x7 +15 and his wheels are pretty flush to the fenders. His pics are in this link
So if you go 15x8 +0, it will sit outside the fenders.
Old 03-17-2010, 02:37 AM   #11
1.5
Form>Function
1.5's Avatar
^^^ perfect thats exactly what I want.
Old 03-17-2010, 04:34 AM   #12
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
im running a 16x7 +38 front and +28 rear (because of pg 10mm spacers)
these pics are with stechs- the wheel gap is actually more noticeable in person.
if you run coilovers you can sit more flush and just increase spring rate- your suspension will travel less and chance of rubbing will be lower (due to stiffer suspension)
Old 03-17-2010, 08:45 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
15X8 +20 with a 225 50 15 barely fits inside the front fender.
15X8 +7 in rear pokes a LOT, with 225 50 15.
Old 03-17-2010, 09:40 AM   #14
coffiend
coffiend's Avatar
Drives: 08 Black LB
If I'm not mistaken, brazdon is on stock rubber, meaning 185/60/15 and s techs.
The taller tire is why his wheel gap is minimal.
Old 03-17-2010, 09:46 AM   #15
coffiend
coffiend's Avatar
Drives: 08 Black LB
15x7 +15 185/55/15 on S. Tech
Old 03-17-2010, 10:56 AM   #16
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
^ another fine example right there. :)
Old 03-17-2010, 12:05 PM   #17
coffiend
coffiend's Avatar
Drives: 08 Black LB
thought maybe this one could help too.
again, S techs and 185/55/15
sorry for the dirty car.
Old 03-17-2010, 01:34 PM   #18
1.5
Form>Function
1.5's Avatar
I want there to be a tiny bit of space I feel like that would alleviate most of the rubbing I would get during street driving. and Im not planning on going with a 225 tire im gonna stretch on something thinner and I am gonna put something low profile so that should also help. I think between the skinny/thin tires and the small gap left with the s-techs I should eliminate almost any rubbing.
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
End of a decade? yaris-me Off-topic / Other Cars / Everything else Discussions 4 12-31-2009 12:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
