Old 04-02-2010, 10:54 AM   #1
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
rear bushings go crunch
anyone else hear their rear bushings make some noise on hard turns, it seems to happen once in a blue moon, but sounds like it's coming from the rear wheel wells, dependent on which direction i'm turning it's usually the outer wheelwell. I'm assuming bushings because it sounds just like it, kinda like a crunch/knock sound and usually just once per that turn. and no, it doesnt go crunch on hard bumps or dips.
it really doesn't happen often enough to give me serious concern, but just thinking ahead as the best maintenance is preventative.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
