Old 04-02-2010, 12:37 PM   #1
bronzebullet232
bronzebullet232's Avatar
Drives: 2010 Black 3dr Lift Back
Question Front Sway Bar
Anybody have a front sway bar on the hatchback? I've been autocrossing a lot lately and want to get rid of some understeer.
My current set up is DF210s, Tokico HP's, 23mm Ultra racing rear bar
bronzebullet232 is offline   Reply With Quote
Old 04-02-2010, 01:57 PM   #2
Try disconnecting the front bar from the control arms first and see how that goes.
Edit: sorry, disconnect from the struts on the Yaris I believe.
You want less front sway bar if you have understeer.
Old 04-02-2010, 05:49 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
what are your alignment specs? a larger front swaybar is going to INCREASE understeer.
Old 04-23-2010, 07:50 PM   #4
mshekleton
mshekleton's Avatar
Drives: 2007 Yaris HB
Um, I'm pretty sure that a larger front sway bar increases oversteer and a larger rear sway bar increases understeer.
*edit*
Ah, you're right:
"Understeer or oversteer behavior can be tuned out by changing the proportion of the total roll stiffness that comes from the front and rear axles. Increasing the proportion of roll stiffness at the front will increase the proportion of the total load transfer that the front axle reacts and decrease the proportion that the rear axle reacts. This will cause the outer front wheel to run at a comparatively higher slip angle, and the outer rear wheel to run at a comparatively lower slip angle, which is an understeer effect. Increasing the proportion of roll stiffness at the rear axle will have the opposite effect and decrease understeer."
mshekleton is offline   Reply With Quote
Old 04-23-2010, 08:31 PM   #5
The Yaris likes a bigger front sway bar a lot. I know on paper it makes a car understeer more, but the reduction of excessive rolling helps the front end stick better in this case.
Old 04-23-2010, 08:34 PM   #6
New2tuning
1st mod project at 35
Drives: 2008 Yaris
*edit*
Ah, you're right:
Paging Dr. mshekleton
New2tuning is offline   Reply With Quote
Old 04-24-2010, 05:50 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
you have an LSD.
totally different
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
front sway bar question thom25 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-25-2009 07:54 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Yaris 24mm Front Sway Bar bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-09-2009 02:33 PM
FS: NEW C-One Front Sway Bar & 4-Point Brace NEW LOWER PRICES! 03Z33 Items for Sale by private party 1 06-06-2009 01:29 AM
