Old 04-06-2010, 02:21 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Cheaper, but still decent quality speakers?
Can anyone recommend some cheaper, but still decent quality speakers to replace the stock ones?
I'll be running them off of my JVC receiver's internal amp. (no external amp. will be used) just like the stock speakers now.
I'd also prefer a set that has decent bass. I have a 10" sub. in the back and would like a little bass from the speakers too.
Old 04-06-2010, 02:43 AM   #2
H3LlIoN
Drives: '09 Yarrrr hatch
this is a relative question. Cheaper compared to what? Infinity's are always nice, and relatively inexpensive...
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 04-06-2010, 02:47 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Under $100 would be great.
Infinity speakers always sounded kind of tinny and metallic to me and the ones I've tried lacked any mids or lows. Those were Kappas though.
Old 04-06-2010, 06:18 AM   #4
AND189
Drives: 2
IsLNdbOi
it is very hard to get a good sound from a car speaker unless you can drown out the car noise and to do that at low cost hmm ebay 2nd hand parts ???
AND189 is offline   Reply With Quote
Old 04-06-2010, 06:33 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
I know that. I just want some speakers that have more low end and mids than the stock speakers.
Old 04-06-2010, 06:41 AM   #6
AND189
Drives: 2
i have some pioneer $120 au for a set they are nice
Old 04-06-2010, 06:50 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Ok. Model number?
Are you running them on a separate amplifier or directly from the head unit?
You can't make a recommendation unless you've tried it the way I've described I'll be running it.
Old 04-06-2010, 06:50 AM   #8
AND189
Drives: 2
i will run to the garage
Old 04-06-2010, 06:52 AM   #9
AND189
Drives: 2
they are pioneer Ts-A1682s 16cm 280w max.
you know how to mount them in the old speaker you just rip out the guts of the stock speaker and screw the new into the stock plastic
Old 04-06-2010, 08:44 AM   #10
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
HIfonics components, they run around 50 bucks on amazon. I have a set of them in my install section.
Old 04-06-2010, 08:45 AM   #11
AND189
Drives: 2
Old 04-06-2010, 08:46 AM   #12
AND189
Drives: 2
yeh sorry mate got all excited about the Ok. Model number part
Old 04-06-2010, 08:49 AM   #13
_S7V7N_
_S7V7N_'s Avatar
25 watts is 25 watts, that's probably the most the Headunit will put out. The components can run on wattages between 2-100 watts.
Old 04-06-2010, 09:05 AM   #14
Palmer812
Drives: 2010 Meteorite Metallic LB
Alpine Type S speakers are good for the money. $100 retail so online will be a bit less.
Palmer812 is offline   Reply With Quote
Old 04-06-2010, 11:41 AM   #15
IsLNdbOi
IsLNdbOi's Avatar
Thanks for the suggestion S7V7N.
The AVX77's manual says it does 20W x 4 channels. Should I find speakers that do only up to 20W RMS?
Old 04-06-2010, 11:51 AM   #16
_S7V7N_
_S7V7N_'s Avatar
The only ones that i seen that were fairly decent were some Blaupunkts Rated at like 35 watts rms, for the price that is. I think the factory speakers are rated at like 10 watts rms. Dude i would just get what fits your taste and eventually save up for a nice 4 Channel amp, matter of fact you could probably get some speakers and an amp that does maybe 50 x 4 for around 120 bucks. Everybody has there own personal preference, Name brand or no name brand, Anything will sound better than them paper speakers that are in there now. I know how it is to be on a budget, Pioneer has some decent budget speakers as well as Sony. Check the Sunday paper, Best buy usually runs speaker specials.
Old 04-06-2010, 07:09 PM   #17
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Infinity refrence 6.5 components... can find them online for cheap... around $100 for a pair. Regardless of what you go with, make sure you buy a pair of components & spend more than $80 online, or $150 in store. Stay away from co-axials/tri-axial/quad-axials... you only need 1 tweet per speaker, having 5 doesn't help sound quality.... if anything it makes things worse, but it does look good for the marketing department, and allows a company to charge more.
Old 04-06-2010, 07:12 PM   #18
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
there is one person on this forum that swears up and down the deck does something like 17x4 rms.... I'd bet its much closer to 10x4 (at any acceptable amount of distortion). Most aftermarket decks are lucky if they can put out 17x4.... I doubt an OEM will be as good, or better than the aftermarket decks... but maybe. Regardless, its best to just save $150 and buy a small 2 channel amp to power your front 2 speakers, and the wires/cables needed to install the amp. It'll sound louder, and you'll notice more bass.
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Needed high quality speaker adaptors for 6.5 and 6x9 for sedan YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 7 09-27-2009 02:43 PM
High quality coilovers avaialble for Yaris? echosqwat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 09-09-2009 06:27 PM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
What do you guys think of this high quality hubcap YarisSedan Cosmetic Modifications (Exterior/Interior) 18 01-15-2009 04:34 PM
