#1 |
![]() Drives: '10 Yaris Sedan Join Date: Jan 2010
Clinking sound coming from front at slow speeds
Recently I've noticed a clinking sound coming from the front at slow speeds. It sounds like a rock tumbling around, and stops when the wheels are moving a little bit faster. I took off the hubcaps thinking it was a rock between them and the wheel, but their was no rock in the there and it still makes the sound.
Could it be something else? It makes no clinking sound when the car isn't moving, or moving faster then like 10-15mphs. Thanks 2010 Yaris Sedan |
#2 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
put car in jack stands and wrangle the wheels, see if you can find it could be a TPMS sensor broken off inside the wheel roll the car in neutral with engine off and a friend walking alongside....listen for noize |
#3 |
No nail in the tire and I don't think it would be a busted CV. The sound definitely makes it seem like something small is bouncing around in the wheel. Would the warranty cover something like this, even if it's just to check it? First issue I've had with the car. It's also my first new car.
#4 |
dealer should check it for free, yes.
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
ive seen a rock stuck in the vein in the center of a rotor before making that noise that goes away at faster speeds.
Have you driven over any construction sites recently? To try to isolate the noise maybe jack up each wheel indepenently and spin the wheel by hand and listen for the noise. |
#6 |
![]() Drives: 07 blazing blue hatch Join Date: Jan 2010
This has happened twice to me in the last two years. There is a very small opening at the top of the brake backing plate where a stone can get between the backing plate and enter the hub of the rotor. Once the stone gets in it can't get out because there is no opening on the bottom. The tinging noise you hear is the stone bouncing against the backing plate.
Remove the wheel, remove the caliper (only two bolts hold it on) and remove the rotor. The stone will fall right out. I just had to do this last week. Last edited by kaly5; 04-08-2010 at 07:58 AM. Reason: typo |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| metal snapping sound on front end when braking... | marcus | General Yaris / Vitz Discussion | 25 | 11-26-2010 10:29 AM |
| Weird rattaling sound coming form the windshield?!? | YarisSedan | DIY / Maintenance / Service | 7 | 12-25-2009 09:28 PM |
| Coilovers - creaking sound from passenger front? | Gideon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 03-16-2009 03:20 PM |
| "Tok" Sound when braking at low speeds (less than 10kmph) | buchieboy | General Yaris / Vitz Discussion | 30 | 02-16-2009 06:50 PM |
