#1 |
![]() Drives: Black HB, 17" TenzoR rims Join Date: Apr 2009
VVT-I setup
A friend of mine told me that he shortened a spring on the VVT-I on his car to activate it on lower rpms, is this possible? If so, can it damage the car in a short term? Thanks.
vvt is always active....it doesnt "kick-in" at any rpm in particular
#3 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
It's also not controlled by spring tension, as a mechanical governor is. The mechanism for rotating the intake cam is controlled directly by the ECU, which opens and closes a hydraulic valve to actuate it for advancing or retarding the cam and gets feedback on the actual cam timing from the camshaft position sensor and crankshaft position sensor. This is why they call it VVT-i. "Variable Valve Timing with intelligence."
#4 |
He gave me a ride a couple minutes ago to test his car. I notice an increase in acceleration at around 3,500 rpm. Now i am confused, you guys telling me it pretty much doesnt work and me feeling some gain on the car lol. Keep the comments going, they are appreciated.
#5 |
maybe on a VVTL-i, but VVT-i engines don't have this "spring" you're talking about. On the VVTL-i, the spring you're talking about connects the slipper follower to the rocker arm. When the rpm's are above the set lift point, oil pressure slides a pin under each rocker arm switching it to the higher lobe of the camshaft giving it more lift for lengthier periods of time
VVTL-I engines have that extra kick but most of the time it isn't seen until far after 3500 rpm. my dad had an '07 Lotus Exige S for a while with the VVTL-i engine and damn did it move. then again it has a supercharger and an intercooler.
1996 Miata Exterior: Aftermarket rims (on car when I bought it), aftermarket glass-window soft-top (also on car when bought) Interior: Alpine H/U Performance: Corksport "Drift" Cat-Back Exhaust, Hard Dog Ace Double Diagonal Roll Bar Future (planned) mods: Intake, bumper turning light "induction" kit, better aftermarket wheels (lighter), light flywheel, upgraded clutch, racing seats, etc etc. |
#6 |
Its a VVT-I. Tis is weird! lol
#7 |
is the car bone stock?
#8 |
look at a dyno of a stock Yaris. You'll see why you feel something at 3500 rpm. It's not necessarily the VVT-i
#9 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
VVT-I JUST KICKED IN YO.
#10 | |
#11 |
this is true haha
fun as all hell to drive, greatly miss it
#12 |
CAI, exhaust, fuel regulator i believe
#13 |
ddong u an idiot lol
#14 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
El VVT-I en los 1nz NO activa. Si se siente mas fuerte a ciertas revoluciones pero NO es un V-Tec o VVTL-i. So NO activa. Veta a dar una vuelta en tu carro ventanas arriba y aire apagado y pisalo en una recta, vas a sentir como por las 5,550rpm "activa" pero NO activa na' es q se siente mas.
I Drive a 129whp Yaris ;) |
#15 |
![]() Drives: 05 Scion xA Join Date: Mar 2010
um , isnt vvt-i activated 24/7 and ran off the throttle pos. sensor and retards when ur not beating the piss out of it and advances when u have the pedal to the asphalt?
#16 |
yaris es toda caminan rico
#17 |
Si Se Puede poner una Trabajar Mejor El VVT -i aqui en Costa Rica lo Hacen vale 1000 dolares Trabajo de El
| Tags |
| rpm, vvt-i, vvti |
| My suspension setup: Breakfast Blend for the angry panda | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 07-26-2010 03:56 PM |
| New "milder" Setup | Loren | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 04-26-2010 10:08 AM |
| N/A setup | Maitre_Te_Te | Performance Modifications | 22 | 12-07-2009 03:24 AM |
| At what RPM VVT should be activated? | Parmas | Performance Modifications | 30 | 11-19-2009 07:40 PM |
| Works bell/Nardi quick release steering wheel setup | blacksandiegovitz | Cosmetic Modifications (Exterior/Interior) | 35 | 09-02-2009 05:52 PM |
