Old 04-09-2010, 11:21 PM   #1
siulung100
Drives: 2007 YARIS HATCH
Another Fog light Topic. Please help me. (pics)
Hello fellow Yaris tuners. these couple of days i have been trying to install my fog lights but i have failed. im getting desperate now.
I bought the kit on ebay, and the seller told me that it was a plug and play, but the wires are completely different from the ones that other yaris users have used.
i have read and studied the other fog light topics, but im still having problems with the inside wiring. i finished the bumper install, grounding the fog lights, and the wire from fog lights is waiting to be conected.
siulung100 is offline   Reply With Quote
Old 04-10-2010, 12:33 AM   #2
1NZYaris1
1NZYaris1's Avatar
from what i can see you have a ugly set up .
lol
Blue wire is earth
one of the red wires with the spade terminal goes to the power in
+ on battery or acc
the other red wire is power out connects to the fog lights power wire
if you want to run it into the Yaris fog light wiring
you need the adptor kit Garm sells at Micro Image .
Old 04-13-2010, 12:33 PM   #3
siulung100
Thanks alot 1NZ, i will try to do it today, and ill give you an update.
Thanks again.
Old 04-14-2010, 01:20 AM   #4
Tardis
Tardis's Avatar
Drives: 2007 Yaris Hatchback
I think I have the same set of lights, first thing is to give all the connectors a good pull as most aren't crimped on worth a shit. I ran the cable into the cabin by nicking a notch into the grommet under the passenger ( right) side floor and into the console. There is a "knockout" under the parking brake that the switch fits into you need to remove the plate and cut it out with an Xacto knife or similar. I had to do some rearranging of the switch pins as it did not work as it was setup. I'll take a pic of my set up and post it when I get a chance.
I wired the relay to the cig lighter(I only use it for my iPod)
BTW The bulbs that came with that setup will last about a month then you'll need to buy good ones!
Tardis is offline   Reply With Quote
Old 04-14-2010, 11:26 AM   #5
If you buy Ray's wiring kit with relay, you won't need to run any wires through the firewall.
Old 04-14-2010, 12:54 PM   #6
siulung100
Cali Yaris, can you post a link to that wiring kit. i cant seem to find them
Tardis i would really apreciate if you post those pictures, thanks man.
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
Fog Light Help cm07yaris DIY / Maintenance / Service 30 03-28-2009 10:19 PM
The right fog light bulb exploded and cracked the lense vacantj DIY / Maintenance / Service 1 08-01-2007 04:07 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
