Old 04-14-2010, 11:14 AM   #1
shifter cable interference?
this was mentioned on echodrivers.com to me this morning and i havent looked in my engine bay yet to check, but how close do the shifter cables come to the header?
i installed a dc on the weekend and someone mentioned i should move/ziptie them out away from the header as they may be affected by the additional head of an unsheilded header
i don't recall seeing the cables near the header, but could anyone confirm/deny their location and whether an unsheilded header would affect them on a yaris (vs an echo)
Old 04-14-2010, 11:23 AM   #2
I don't remember them being particularly close to the header. I can't be of much help though, unless JR brings his yaris to work.
Old 04-14-2010, 11:30 AM   #3
minnyar
Drives: 2007 Yaris Sedan (5pd)
Having spent enought time ripping the skin off my arms yesterday I would say everything is close in the engine bay of a Yaris. That being said there is enough clearance that there shoudln't be any issues.
minnyar is offline   Reply With Quote
Old 04-16-2010, 12:56 AM   #4
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Does the question pertain to a Yaris or an Echo?
It's been a while since I did mine, but I'm pretty sure there was a bracket that holds the shifter cables away from the header anyway. As long as they're not touching the header it will be fine.
*Edit* I just looked at it and the shifter cables are about 8" away from the header. The 02 sensor wire is close, but it's shielded, has a brace holding it away from the header, and it was always there anyway.
Old 04-16-2010, 09:36 AM   #5
thanks for taking a look TG
i knew the o2 sensor wire was close, but it has that hanger.....i never noticed the shifter cables....but it came up on echodrivers.com that they MAY be close, so i asked here
TRD SSK & Shift Cable Bushings Issue/Question minnyar Performance Modifications 5 04-14-2010 10:50 PM
Bronzoil Cable Bushings for the Yaris/Echo now available! TWM Performance TWM Performance 58 03-31-2010 10:19 AM
NST shifter cable bushing users: Lube up! schleppy Performance Modifications 11 07-05-2009 08:47 PM
Stock Shifter Shafts TWEAKED_ICE Performance Modifications 8 06-02-2009 07:20 PM
NEW NST SS Shifter Bushing (AE86) NonStopTuning NonStopTuning 3 10-01-2007 03:12 PM
