Old 04-15-2010, 10:53 PM   #1
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
probably a long shot but: HUB SWAP??
alright, ran into a slight problem fitting porsche wheels onto my girlfriends yaris.
so here goes: any body have any idea if it would be possible to swap a VW style hub (or even VW hubs for that matter) onto a yaris? i need this to happen somehow, im super determined.
sasquatch is offline   Reply With Quote
Old 04-15-2010, 11:17 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Probably easier to fill and redrill the wheels.
Old 04-16-2010, 09:01 AM   #3
severous01
why not do a spacer/adapter? if you re-drill the holes then the wheel will wobble. i had a friend in jersey put BMW 7 whels on his camaro...they were off just a bit so he widened 2 holes...he ended up snappin lugs.
if it doesnt fit right...something's wrong. and if it's wrong, then it wont work right...any way, do what you will. there's worse things on the road than someone trying to rig up some wheels.
Old 04-16-2010, 09:37 AM   #4
I looked into lug conversions a long time ago. I had some 5x100 wheels off my tC I really wanted to try on the Yaris.
The only ones I could find that would be of safe and good quality were at least 1" thick, and that wouldn't work for me. So that's where I left my quest.
Old 04-16-2010, 11:11 AM   #5
kimona
kimona's Avatar
In all likelihood, you won't have room for adaptors. Filling existing holes is relatively easy and safe, and can be virtually invisible. Redrilling can be completed with absolute precision by the right shop. It wasn't long ago, that vendors routinely stocked blanks and only drilled wheels to meet specific application requirements.
Old 04-16-2010, 12:31 PM   #6
sasquatch
well i do have a set of HR adapters sitting in my garage. the problem i'm running into is that where the existing studs come though i don't have/cant find a lug nut small enough to fit in the hole on the adapter. and the way that the 4x100 and 5x130 bolt pattern overlap there is hardly any room to open up the hole.
also kinda leaning against filling and re-drilling because of the way the wheels are drilled, i don't want them to look like shit.
wheels in question, so you can see what i'm talking about.
Old 04-16-2010, 01:27 PM   #7
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Don't be stupid , just go and get some knock off wheels that fit and put a porsche sticker on them
Done
Old 04-16-2010, 02:31 PM   #8
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
get an adapter and take a hammer and metal pipe to the fenders.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 04-16-2010, 03:53 PM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
you are inflicting your self with soooo much pain! why!??
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-18-2010, 02:43 PM   #10
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
What about swaping all of your hubs over to an xD's (which are 5 lug) then gettin an adapters for those?
Old 04-19-2010, 07:59 PM   #11
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
with the amount of money it would cost to do a conversion, in the end it simply isnt worth it.
just use that money that you would spend going through all that headache and find some 4x100 wheels you like
we get crappy selection but there are some great wheels out there if you look
Old 04-19-2010, 09:07 PM   #12
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
DO AS LILREDROCKET SAID THEN GO TO https://uswheeladapters.com/Home_Page.php
OTA'sTOY is offline   Reply With Quote
Old 04-19-2010, 09:31 PM   #13
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
get some mini wheels, they look good and ligth and just slap the porsche logo on them
cruz-gsr is offline   Reply With Quote
Old 04-19-2010, 09:48 PM   #14
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
This is the best idea proposed in this thread. You should be able to pick up a used set for around $250 and bolt them on, no muss, no fuss.
Old 04-20-2010, 11:09 PM   #15
sasquatch
i know its not the most economic option but there is a first time for everything. doing what it takes to hopefully get it done is something im willing to do. i have the wheels because i was going to put them on my scirocco, but decided they would look a lot better on my girlfriends yaris. along with a few other sweet mods coming soon :snky snky:
im calling someone at adaptec tomorrow to see if they can help. its pretty much a challenge at this point. i'm not a car snob by any means, but replica parts and putting porsche sticker/centers on a wheel that looks nothing like the phone dials is something i'm not down with. legit or nothing for me.
Old 04-20-2010, 11:26 PM   #16
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Good luck, I think they would look great on a Yaris. That said, the "phone dial" wheels are pressure cast. They aren't forged or machined from billet, either of which would be a better candidate for filling the of the old holes. Pressure cats aluminum does not take well to "filling". Filling and re-drilling is not a safe option on these wheels IMO.
Stove is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
DIY aftermarket steering, hub, quick release install AlainMikli DIY / Maintenance / Service 17 07-20-2009 06:01 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
