Old 04-23-2010, 11:34 PM   #1
michaelhay
Drives: 2010 5-door hatchback
Driver Window Weatherstrip problem?
Hi,
I got a new 5-door Yaris six months ago. I like everything about it except this one little annoying problem: the horizontal weatherstrip (the one that looks like a long squegee) of the driver side does not touch the glass. When I roll the window down, it does not get wiped.
(it works fine on the passenger side).
Has anyone encountered this problem?
Any solution?
Thanks
Michael
michaelhay is offline   Reply With Quote
Old 04-24-2010, 12:31 AM   #2
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
You can take it back to the dealer and have them check to see if the wiper seal is installed correctly and/or adjust the window tracks/mechanism so the window contacts the wiper seal. It should be covered under warranty since its a workmanship issue.
-or-
It should be something you can do yourself if you are even slightly mechanicaly inclined. I havent been inside the doors on my Yaris yet but every other car that I've had has room to adjust the window tracks/mechanism so you can get the window into the proper position.
For starters ,here is the Yarisworld 30 second door panel removal DIY (for the lift back Yaris).
CLICK ME
Stove is offline   Reply With Quote
Old 04-24-2010, 02:15 AM   #3
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
take it to the dealer, have them look at it since its still under warranty
if they find signs that you messed with it they might not cover it under warranty
OTA'sTOY is offline   Reply With Quote
Old 04-24-2010, 05:50 PM   #4
michaelhay
Thanks
Great, thnks guys for the great advice.
I will take it to the dealer then.
So your Yaris doesn't do that, does it? both windows get wiped fine when the window is rolled down/up?
Thanks
Michael
Old 04-24-2010, 08:38 PM   #5
swidd
Drives: Yaris HB
My 2007 HB wipes the windows of rain, dew and very light frost, by cycling them down and up.
Old 04-25-2010, 05:29 AM   #6
Kongo-Otto
Drives: '09 Yaris & '10 Auris
My Yaris doesn't wipe off anything from the windows, too.
Old 04-25-2010, 10:05 AM   #7
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Mine does the same thing . So did my Evo . I just use the 55 mph method in conjunction with Rain-X . No problems ....
Old 04-25-2010, 11:13 AM   #8
127.0.0.1
it is not a flaw. the seal is there to keep garbage
out of the door when the window is up
when you drop the window it is not designed to keep the seal
pinned against the glass. if it does fine, it is does not that is not a flaw
many vehicles work the same way. it is not a -wiper-
Old 04-26-2010, 09:14 PM   #9
yeah.. it's not a wiper :P
it's supposed to only touch the window when it is up... I would rather have it not touch the glass at all... one less thing that scratches my window!
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 07:13 PM
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 10:03 PM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 7 09-22-2010 03:22 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 09:11 PM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 10:18 AM
