#1 |
![]() Drives: 2001 Toyota Vitz Rs Join Date: May 2009
ITB swap
Hi, i'm new in here and i own a vitz rs with the 2nz engine. I am consiedering in purchaseing an itb to keep it n/a. I already have some mods in the engine such as a custom made 4-2-1 exhaust manifold, lightened flywheel, ported cylinder head and a very good custom made induction kit.
The thing is that i don't know from where to begin! Do i need to change the camshafts? What ecu or piggy bag do i need and what is the best ITB to be fitted on? I was considering in buying the Honda CBR600 ITBS or the 4age ITBS and someone told me that with an Apexi afc neo i could work without buyin a stand alone ecu... Is it true? Cheers
Well....There isn't a ton of info out there. It's good that you are in Malta, since the only once I've ever seen this successfully done on is in Greece. I don't speak Greek, but here is their website....www.yarisclub.gr
Keep us posted! Do you have dyno numbers with your mods? Who made your header? Thanks, and welcome!
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
#3 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
I would expect going IRTB on a Yaris to be disappointing under most circumstances.
You gain: Throttle response Top end power Cool intake noise You lose: Low-mid range torque Effortless daily driving I've not seen it done on a Yaris, but I've seen a few Miatas with IRTBs, and unless you're just drag racing or doing it for the cool factor... it doesn't seem worth it. Honestly, I'd skip the IRTB and just go with custom engine management so that you can tune the engine to make better use of the mods that you already have. You might get better peak HP with the IRTB setup, but I'd bet on even the stock intake to provide a fatter torque curve throughout the rev range. As the wise old-school racers say: "It's the area under the curve that counts." |
#4 |
Found it...member "Kekropas" is the one running ITBs
Here is his setup. http://www.yarisworld.com/forums/sho...5&postcount=16
#5 | |
Note: requires standalone ECU. That is a BIG project. Sexy though!
#6 |
Slowy getting there
Why does TS matter?
#7 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
ts comes with more power bigger engine
#8 |
Slowy getting there
Did you read the post? It says 1NZ.... Again why does TS matter?
#9 |
^ lol
Did you read the post? It says 2NZ.... Again, TS matters.
#10 |
Slowy getting there
What post are you talking about? I am talking about the link in post #4 that is about the only know user running ITB's that has posted on YarisWorld... Did YOU read? SO why does the fact that he has a TS matter? The OP of this thread has a RS not TS. Also the 2NZ is smaller...
#11 |
Ooops my bad. Getting my NZs mixed up. Anyway, the TS is a 1.8 litre is it not.
#12 |
Slowy getting there
Not in the Echo I guess. If you look at the link that was posted about it says he is running the 1NZ with ITB, standalone, and custom 4-2-1 header and making 145hp.
#13 |
The older TS is a 1.5. 145whp is good.
#14 |
1nz or 2nz its the same intake manifold setup....the only difference is the piston travel for the 0.2L difference
just buy a greddy supercharger for an xb/echo
#15 |
The header was made here in Malta by ZISCO.. He took the exact measurments etc... Well regarding the itbs i would like to know wether kekropas did fit them on standard cams or not!!? I think that it would be a great mod since at the moment i've only got the 4-2-1 header and a good induction kit!!.. I just drag raced a yaris turbo and his time was 16.3sec and mine was 16.7sec:) Btw this is my baby vitz...
![]() The custom made air duct... ![]() At the Malta Drag Race Track...
#16 |
love that air duct!
#17 |
Slowy getting there
Do you have any pics of your header?
#18 |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| 09 Meteorite Metallic Front Swap | RacerFreakXXX | Items for Sale by private party | 13 | 07-24-2009 07:22 AM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
| mid pipe swap | shinlee | Performance Modifications | 0 | 02-09-2009 10:44 PM |
