Old 05-12-2010, 09:01 PM   #1
SilverY
SilverY's Avatar
Drives: Silver Base Yaris Sedan
Post HID, power lock/window, wack alarm removal Question....i think lol
hey yaris world....
i have a 2007 sedan yaris base...
no power windows or locks
a wack alarm that jus rings but wants it removed
and i have a h.i.d. set that i placed in...
with the HIDs should i have a kit? i went to mircoimage and dont know which one i should get...
i want some power windows...whats my options?!?!
can i go power to the front windows and route the 2 back windows to jus 1 remote for they can go up an down together
locks
can i get a kit where i can lock my door and all the doors lock, or jus a reg power lock kit for all 4 doors
and how can i remove my cheap alarm system. i dont know what wires to remove so i just left it alone..
thank you
'07 Yaris Base Sedan - 25% 30% tints - Batman logo (gone) 2ft aux cable - 7k H.I.D. Artic Blue
http://www.cardomain.com/ride/2599926
SilverY is offline   Reply With Quote
Old 05-12-2010, 09:12 PM   #2
severous01
hids, or HID??? HID is a bulb, ballast, wires to connect to what type of harness you got.
that's a basic kit. more advanced kit includes bushings/seals, relays, fuses, wires, bulbs, ballasts, instructions, connectors.
also, you have to consider bulb color, thin or normal ballast, whether you need relays and fuses or not, and wether you want a true dual filament (4 ballasts) bulb, a shield that moves for high beam, or a single HID and a halogen high (no way in my opinion...)
of course, the more you spend the better you get.
as the alarm goes, pull the fuse and leave it if you dont wanna mess w it. but, if you want it gone, you gotta trace every wire and cut it out and make sure the OEM wires are covered, reconnected, or spliced back.
Old 05-12-2010, 09:23 PM   #3
SilverY
SilverY's Avatar
i have jus the HID bulbs in. no kits jus pluged them in. i have the 7k artic white h4. and i jus placed them in, but if i had the kit id imagine it would be much better.
Old 05-12-2010, 10:34 PM   #4
severous01
you have halogen bulbs installed.
there is no way that you have 'hid' with just a bulb replacement. there are ballasts, and some wires involved. if you just put a bulb in the socket and put stock wires to it then you dont have HID. you have a halogen bulb with tinted glass.
alarm, hid, power locks, power windows
Question about the security alarm system YarisFan007 Cosmetic Modifications (Exterior/Interior) 1 02-25-2011 07:45 PM
Help! MES power lock install question mr_thunder16 DIY / Maintenance / Service 5 11-13-2009 08:50 AM
power locks and alarm install acrbill In Car Entertainment + Electronics (audio / video / alarm) 1 12-01-2006 12:17 AM
