Old 05-25-2010, 04:14 AM   #1
yarringyaris
Drives: 2011 yaris sedan
problem??? help plzzz
So while driving my toyota yaris' which is brand new. while crusing at about 1.5rpm going about 20mph i get random surges in acceleration, its noting significant but i personally can feel it when im on the brake or gas pedal.
anyone have any inputs??
yarringyaris is offline   Reply With Quote
Old 05-25-2010, 10:56 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Normal. Cruising at 20 MPH requires only a fraction of a horsepower to maintain speed on level ground. The throttle's right on the edge of cutting back to idle. The ECU switches in and out of DFCO (Deceleration Fuel Cut Off) mode, causing the surging. When the engine's coasting with no power, no fuel is being injected at all and the pumping losses produce a drag. Then it switches back to slightly above idle power and surges ahead.
The changes in drag you feel when you're on the brake are due to the transmission shifting, if you've got an automatic.
Old 05-25-2010, 12:26 PM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
Agree with YH. Also, the car will run better as it breaks in. Surging at low speed will be normal on most any car.
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
