Old 06-03-2010, 03:38 PM   #1
tadc
Drives: 07 Liftback, Red
Hard starting, but only once... so far!
Greetings all - thanks for participating in such a great forum.
My wife has an 07 Yaris automatic with about 43k miles on it. So far it's been nearly flawless (despite the TWO body-shop visits it's required due to... 'mishaps').
The other day, she went to drive the car to work and it didn't start on the first try - and it's always fired up pretty much instantly in the past.
She hit the key and let it crank automatically (as usual) and it gave no hints of starting. It seemed to crank at the normal speed and duration.
She tried again several times, and on the fourth or fifth try it started normally with no apparent issues. Since then we've driven the car several times and it hasn't repeated this behavior.
I had started the car a few hours earlier that morning and ran it briefly - just long enough to move it out from behind my car. I've done this many times in the past with no apparent issue.
Actually I lied earlier - just ONCE it did take an extra second or so of cranking to start. But that was months/years ago...
Any thoughts on what the car might be trying to tell us(other than it's just gone out of warranty)? :) Something flaky with whatever sensor that tells the car to fire the plugs? Dirty fuel filter? Some kind of air leak in the fuel system?
Thanks for any thoughts.
tadc is offline   Reply With Quote
Old 06-03-2010, 03:49 PM   #2
1stToyota
1stToyota's Avatar
I could be incorrect, but it seems like this issue happens infrequently, but mostly with owners that bump the key just enough to let the ecm do the automatic cranking/starting...don't think it's been an issue w/ the ones that start their Yaris' the old fashion way.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 06-03-2010, 04:16 PM   #3
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
If you have the owners manual there is a section in there regarding the security system and the chip in the key. Given the info in that section concerning interference from key rings etc, I've come to expect an occasional starting glitch once in a while. Hasn't happened yet though. I don't keep much on the key ring though.
Do you have a lot of keys/metals on that key ring? If so you might try addressing that first.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-03-2010, 04:30 PM   #4
tadc
Thanks for the quick replies!
1stToyota- so you're suggesting it's a glitch with the "automatic" starting? I assumed that if the starter was running, everything else would function as normal, but I guess I could be wrong.
R2D2- I'm pretty sure this Yaris is free of any electronic wizbangery. It's a real stripper - no ABS, no power windows/locks, not even a rear wiper. In fact it didn't even come with a radio (although speakers and wiring were in place!), but I quickly rectified that problem.
From looking at the key, I'm pretty sure there's no chip or other electronics. It's the same generic Toyota key blank they've been using since the 80s.
She does have a fair amount of crap on the keyring though...
Old 06-03-2010, 10:00 PM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Like 1stToyota said, there are a bunch of old threads on this forum describing the same thing, and it's usually turned out that the person with the problem was just quickly bumping the key and letting it start itself. Hold the key in the start position a little longer, and it works.
Toyota yaris 2002 - Hard clutch abhinav_kr DIY / Maintenance / Service 10 06-29-2016 07:08 AM
hard time putting bumper back on ezhacker1 DIY / Maintenance / Service 4 05-03-2009 08:59 PM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
hard starting after moving car gonzo452001 DIY / Maintenance / Service 12 06-09-2007 05:07 PM
