#1 |
So, I ordered a fog light kit from Garm, but I've decided to go with the OEM headlight stalk instead of ripping apart my interior and splicing wires.
I'm still waiting on the stalk from my dealer, and know I can handle the engine bay portion of the install, but the question I have is, can you replace the light stalk without pulling off the entire steering wheel? From what I understand, you can just pull off the steering wheel shroud and pop in a cruise control stalk or intermittent wiper stalk... but does anybody know if the same holds true for the headlight stalk?
![]() ![]() Drives: 09 Yaris 3 DR HB Join Date: Jun 2009
sorry, you've got to pull the wheel off. when u receive the part you'll see why.
#3 |
Bummer, maybe I can sweet talk the dealer into swapping them out. (Messing up the airbag is my main concern...)
Thanks.
#4 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Good luck asking the dealer to do it. First time I did this mod. I went to the dealer and they wouldn't do it. I went to some other auto body and repair shops and no one wanted to touch it (the airbag). All of them said things about it being a liability.
#5 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
It's a good way to get yourself killed or maimed if you don't follow the proper procedure. There's a lot of power in those airbags.
#6 |
Does this DIY look pretty accurate for this undertaking?
http://au.toyotaownersclub.com/forum...howtopic=22446 (I couldn't find anything that in-depth on YW...)
#7 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Just make sure you don't twist the clockspring too much, there is a really delicate ribbon cable inside (I snapped mine with little force while changing my headlight stalk).
And also make sure to leave your battery disconnected for at least 5 MINUTES prior to removing the airbag contacts, else you have a chance of setting it off. Also make sure to place the horn/airbag with the Toyota symbol facing down, in a place where it won't be hit or touched by anything. Once you get past that it's really not hard. :) |
#8 |
It's going to be about a week or two before I pick up the stalk up, but I've been looking around to make sure I've got this figured out so it's good to go once I've got all my parts. Once I have everything ready, the battery will be disconnected while I pull the bumper off, which I'm sure will take a good bit of time (Slow is smooth and smooth is fast.).
(first attached image) So, the clock spring should be in the "centre spiral assembly" in step 16 of the DIY from my previous link, correct? (second attached image) And obviously the center pad contains the airbag, which I'll try my best to treat it like I'm an EOD tech defusing a bomb.
#9 |
The first picture the guy is actually holding the clockspring in his hand - it's that whole black plastic thing.
#10 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
wtf? y are ur lights and wipers on opposite sides then mine?
#11 |
Those are pictures from that Australian site isn't it?
#12 |
hey i tried to do that... go tired of messing with it and just ran the aftermarket switch. but kept that switch installed.... useless but installed.
#13 |
Yes, those pictures are from an Australian DIY, so they are reversed.
I think I've got this pretty much figured out:
#14 |
I changed mine out its pretty easy to do. The hardest part was getting the torch screws loose to remove the steering pad. I have pics of my disassembly ill post them for u to follow. Oh n make sure when your new stalk comes not to remove the red tabbed ring
#15 |
Thanks bizzlebaby, any more info that I have will make things easier!
I'm going to have to put together a nice DIY guide when I'm done with this.
#16 |
its really pretty easy todo.. the "hardest" part was getting the old light stalk to unsnap out of the housing its clipped into. i had to be a mean with it haha. but dont get to ruff tho
#17 |
My pics r on my other memory card so I will try to post them late tonight .... if u make the dumb mistake of pulling the red thing off you will have a hard time getting the new stalk on... its purpose is to hold the stalk opening open so u can easily slip it on the steering column. I removed it n most if my installation time was trying to pry that piece back open.
#18 |
When I got my stalk out of the bag, the red thing was in there separate from the stalk.
Anyone have a clue how it's supposed to go back on, and if it's just a temporary thing used to aid in putting on the stalk? Should be putting this all together this weekend, so any help before I go from the shallow end to the deep end of the "Yaris mods pool" would be great!
| DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) | CTScott | DIY / Maintenance / Service | 142 | 06-25-2024 01:47 AM |
| DIY Variable Speed wiper stalk install | DanQ | DIY / Maintenance / Service | 27 | 08-03-2017 07:22 PM |
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
