Old 06-08-2010, 04:54 PM   #1
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
cel-maf sensor
so lately i been popping a cel p0101 which i looked up and it was my maf sensor acting up. i am currently running a blitz sc, 1zz fuel injectors, fujita cai. i have had no problems running this setup for almost a year. now i am always throwing a code, i have cleaned the sensor multiple times and it just seems to throw this code alot. is it time to buy a new maf? i have also noticed that the oring is wearing out, would that play a big factor? thanks for the help.
staypuft is offline   Reply With Quote
Old 06-08-2010, 06:19 PM   #2
auxmike
auxmike's Avatar
I've been buying mission critical spares little by little.
Cheap insurance.....
Old 06-08-2010, 07:07 PM   #3
staypuft
aka SDMF
staypuft's Avatar
yeah ill be dropping by the dealership later and picking up one
Old 06-09-2010, 09:02 AM   #4
hatchbackkid82
Drives: .
how much for one of these sensors?
Old 06-19-2010, 08:06 PM   #5
staypuft
aka SDMF
staypuft's Avatar
update, so i bought a new maf and 1 week later still popped a cel, im thinking i should just put my stock airbox in to test if it the cai, its weird since i had the cai for almost 3 years and this is happening.
Old 06-19-2010, 11:40 PM   #6
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Do you have any pending codes?
Old 06-19-2010, 11:44 PM   #7
staypuft
aka SDMF
staypuft's Avatar
p0101, thats it, im thinking of putting back 1nz injectors or changing back to stock airbox, the last mod i did was changing the injectors. so i will start with that i guess
Old 06-19-2010, 11:53 PM   #8
lilredrocket
Slowy getting there
Drives: 08 Liftback
What type of code reader are you using?
Old 06-19-2010, 11:59 PM   #9
staypuft
aka SDMF
staypuft's Avatar
i have a scangauge, and my buddy used some other highend reader, not sure of the brand but he said it the same as the techs use.
Old 06-20-2010, 12:10 AM   #10
lilredrocket
Slowy getting there
Drives: 08 Liftback
Get your friends again and see if you have any pending codes. My scanner at work can read them
Old 07-12-2010, 02:32 PM   #11
JImbo_2400
Drives: 2D Grey Hatchback
I've had the same problem. I put in a K&N cai and after about 200 miles the cel came on with the P0101 code. I called K&N and they couldn't explain it, they just kept saying there must be vacuum leak somewhere but I put hose clamps on every vacuum line and checked all the connections on the cai but no luck. I just drive it now with the light on.
JImbo_2400 is offline   Reply With Quote
Old 07-12-2010, 05:17 PM   #12
yarrr
Drives: 07 sedan
For the fujita, search on MI forums for fujita fail. Make sure the support didn't rip a hole in your pipe as has happened to 2 users.
Also, on my SRI, I used a silicon sealant in between the pipe and the MAF. I've yet to see a CEL or have even a second of rough idle or anything.
pieza para el sensor maf paveovisual Central and South America 17 09-10-2012 04:34 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
WTB 2 screws hold down MAF sensor detroiter Willing to Buy by private party 7 03-12-2010 03:35 PM
WTB stock maf sensor screws Grandieri Willing to Buy by private party 2 04-30-2009 11:47 AM
CEL Issue via MAF Sensor, Thoughts? The Architect Performance Modifications 8 03-29-2009 11:50 PM
