Old 06-13-2010, 07:32 PM   #1
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
fog light wiring
Does any one sell just the wiring for the fog lights?
i already have the fogs, many switches and relays, all i need is the wiring.
Thanks
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 06-13-2010, 08:01 PM   #2
1NZYaris1
1NZYaris1's Avatar
i have some here What part of the wiring are you after .
from the lights to the under bonnet fuse box ,
do you have the factory relay .
let me know what you need .
Old 06-13-2010, 08:03 PM   #3
Cosmonaut
The Last Baron
Cosmonaut's Avatar
well to make it easier im looking for the entire wiring kit, fog lioght to the bonnet fuse box and everything inside the cabin.
| UR 19mm sway |
Old 06-13-2010, 08:09 PM   #4
1NZYaris1
1NZYaris1's Avatar
Theres no wiring in the cabin apart from your switch , (which you say you have )
i can send you the parts to make any 3 pin switch plug and play
and a wiring diagram
Old 06-13-2010, 08:19 PM   #5
Cosmonaut
The Last Baron
Cosmonaut's Avatar
when i say switch i mean i have a generic toggle switch. I think i saw some one who had one like that( ctscott ithink)
| UR 19mm sway |
Old 06-13-2010, 08:31 PM   #6
1NZYaris1
1NZYaris1's Avatar
Okay so you want , The engine bay wiring , and for it to plug into the fuse box , under the bonnet .
Inside the car you want the factory relay and the aftermarket kit switch
that will plug and play
if that is correct your looking at $48.US Shipped
complete with instructions .
This loom will only plug into H11 Foglight Bulbs as per the factory .
Old 06-13-2010, 08:40 PM   #7
Cosmonaut
The Last Baron
Cosmonaut's Avatar
check pm
| UR 19mm sway |
Old 06-13-2010, 08:51 PM   #8
1NZYaris1
1NZYaris1's Avatar
no Problem , as i PM'ed back .
micro Image should have these Kits available soon .
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
