Old 07-22-2010, 07:28 PM   #1
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
Custom Exhaust...could use some input
I cant find too much on the flowmaster 60 series of mufflers around here...yes i have searched. after debating for a long time on whether i should go axle back from garm or custom cat back, i've decided to go custom. my initial plan is to go 2.25 pipe stock res and run the flowmaster 60 muffler. has anybody heard these mufflers on a yaris in real life? i'm wanting a good deep aggressive sound without being loud and doesn't drone while cruzin. if you think there is any out there better than the flowmaster let me know :)
SLIK4 is offline   Reply With Quote
Old 07-22-2010, 07:58 PM   #2
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
I have the Tanabe Medallion which is advertised as "discrete" and "under 93 db" and is hecka loud Compared with the stock exhaust anyways. I sound-proofed the floor in the rear which improved the noise level in the cabin a bit, but it's still hecka loud
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 07-22-2010, 08:00 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
2.25 is too big for this car if you dont have other major upgrades.. 1.75-2.0 diameter is better..but thats just me..
Old 07-23-2010, 11:44 AM   #4
hatchbackkid82
Drives: .
i think the nitto mid pipe is 2 inches, like marcus said i wouldn't go any bigger than that
Old 07-23-2010, 12:55 PM   #5
SLIK4
Michael
SLIK4's Avatar
thanks guys :) i can do 2in no problem. now does any know about the flowmaster 60 series and how it will sound?
Old 07-23-2010, 12:55 PM   #6
2" is good, you'll retain some back pressure and maximize your hp gains.
I used that muffler before, nice rich deep tones. I use Vibrant now, but the Flowmaster is very good.
Old 07-23-2010, 05:21 PM   #7
shinlee
shinlee's Avatar
Drives: 07 liftback
i'll try to post up some video clips foryou, but I ran the 60 for over a year, and loved every part of it. It sounds perfect (as do all flowmasters) at full throttle, but being a 60, it was not just subtle, it sounded almost exactly stock at idle. I'm a big fan of that, cuz i hate sitting at a light listening to my muffler, ya know? I think it's the best sounding thing out there personally, but that's your call.
shinlee is offline   Reply With Quote
Old 07-23-2010, 05:24 PM   #8
shinlee
shinlee's Avatar
Drives: 07 liftback
http://vids.myspace.com/index.cfm?fu...deoid=32350826
stock exhaust
http://vids.myspace.com/index.cfm?fu...deoid=32351315
straight pipe (no muffler at all, ran on a 2'' pipe)
http://vids.myspace.com/index.cfm?fu...deoid=32352422
60 series on a 2'' pipe
I included the stock so you could tell the difference, since my camera sucks nuts, sorry bout that!
Old 07-23-2010, 06:20 PM   #9
SLIK4
Michael
SLIK4's Avatar
thanks alot for the sound clips Shinlee
alright so i'm def goin with 2in piping and more han likely the 60 series thanks to Shin. next ? is should i keep the stock res or go with a glasspack in its place? what exactly would the glasspack do to the sound? and how long of a glasspack should be used?
Old 07-23-2010, 08:14 PM   #10
shinlee
shinlee's Avatar
Drives: 07 liftback
well, if you want the drivability (i.e. less noise when you're cruising at highway speeds) the stock res is fine. Hell, irregardless, the stock res is fine if you're running a 2'' pipe. I personally looked at it myself before my exhaust was put in, and it is a straight flow through 2'' center resonator. (That's why I chose 2'', no point going bigger than the smallest point on the system, ya know?) So a glasspack or stock res should net exactly the same power, just differnt noises :)
Old 07-23-2010, 10:23 PM   #11
SLIK4
Michael
SLIK4's Avatar
what kind of noise difference would the glasspack make? louder or quieter? deeper maybe?
Old 07-24-2010, 05:54 PM   #12
shinlee
shinlee's Avatar
Drives: 07 liftback
my personal experience is it makes it louder, but you wouldn't get much deeper just due to the motor i'd imagine.
Old 07-24-2010, 06:50 PM   #13
SLIK4
Michael
SLIK4's Avatar
thanks for all your help shinlee, i appreciate it. you too garm :) last question is i'm not 100% sure on the order of things on the stock exhaust. is there just one resonator after the cat or two? if there are two then which one would i want to replace with the glasspack?
Old 07-24-2010, 07:28 PM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
This is exactly what I'm looking for. Thanks for the good review, shinlee!
Which resonator did you go with? The smallest diameter one on the Flowmaster site is 3" and offset on both sides:
http://www.flowmastermufflers.com/sh...oducts_id=2299
Old 07-25-2010, 04:28 PM   #15
shinlee
shinlee's Avatar
Drives: 07 liftback
the stock resonator on the yaris is fed by a 2'' inlet/outlet resonator. The piping ahead of the res is 2'', but behind it it drops to like 1 3/4'' or something, that's why I went 2'' on from my res back to the 60 which was a 2'' inlet/outlet as well :)
Old 07-25-2010, 04:31 PM   #16
shinlee
shinlee's Avatar
Drives: 07 liftback
60 series
straight pipe
make sure when you're having your 60 installed, try to find a better mount point than my muffler guy did, I had to go back and fix it up later. A little more time in planning makes for a better placement, cuz it's a tight fit in there, especially when lowered on df210's
Old 07-25-2010, 06:03 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
exhaust velocity is more important than "backpressure"
Old 07-25-2010, 08:41 PM   #18
SLIK4
Michael
SLIK4's Avatar
thanks for the pics! i was hoping i could use the center inlet offset outlet 2in style and fit it in like this one...http://www.yarisworld.com/forums/sho...hp?t=9520...do you think it would fit?
Custom 1.75" catback exhaust - worth it?? fuji Performance Modifications 4 05-09-2009 06:46 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Custom exhaust or pre-made exhaust - which one makes more power? fuji Performance Modifications 9 03-08-2009 12:24 AM
Custom Cat-Back exhaust Yaris TS CASTREX Yaris TS Talk 16 10-24-2008 12:56 PM
How much has your custom exhaust cost you? whooppee777 Performance Modifications 7 07-21-2007 11:20 AM
