Old 08-09-2010, 02:31 PM   #1
yariscrazy67
Drives: green 2007 yaris
Need an AC expert
Ok, so here's my problem, I have a 2007 sedan and my ac will not start cooling for about 15 minutes after I start my car. After that, it cools fine. The compressor is not running during that time. The blower blows warm air, and then it just starts blowing cold air. Anyone have this problem?
yariscrazy67 is offline   Reply With Quote
Old 08-09-2010, 02:48 PM   #2
Considering that you have an 07, do you ever see your alternator light flickering?
The AC Amplifier (which is the ECU for the A/C) controls the cycling of the compressor. There are many reasons why it would not turn on the compressor (including things like refrigerant volume or pressure issues), but the AC amplifier also gets a signal from the alternator that tells it that the alternator is running. This prevents the AC amplifier from running the compressor when it will kill the battery. There is a common problem with 07s (and a TSB for it) with the voltage regulator within the alternator becoming corroded.
Old 08-09-2010, 06:53 PM   #3
yariscrazy67
Thank You very much for you help.
Old 08-11-2010, 02:52 AM   #4
birdman
Glad I got an '08
Photoshop expert, Pls Help!! Anyone? evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-19-2010 08:44 PM
Geek or Computer Expert help me out? jamal1984 Off-topic / Other Cars / Everything else Discussions 5 03-23-2010 11:37 AM
Computer Expert Help jamal1984 Off-topic / Other Cars / Everything else Discussions 6 11-26-2008 11:33 PM
This Question is for Digital Camera Expert ! jamal1984 Off-topic / Other Cars / Everything else Discussions 20 07-18-2007 02:00 PM
