Old 08-17-2010, 12:06 PM   #1
JCHanlon
Drives: 2007 Sedan
Help removing dash
Ok, I am kind of a tall guy. I was sitting in my 2007 Yaris, talking on the phone. I had my knees resting on the AC control panel, well my knees pushed the controls through the panel. Is there an easy way to remove the panel and push them back through?
JCHanlon is offline   Reply With Quote
Old 08-17-2010, 12:28 PM   #2
Yaris PAVEL94
if you have the sedan the way to take it out is take out the small peace on the bottom of the as with your hand and then the side ones again with your hand, then take the radio out with a skrewdriver there are 4 bolt and take the connections out. the there are 4 bolts on the ac and you can fix it from the back. good luck
Yaris PAVEL94 is offline   Reply With Quote
Old 08-17-2010, 01:33 PM   #3
JCHanlon
Drives: 2007 Sedan
I have seen a video on the web but the way the contols are set up are different. Mine make a triangle, the ones on youtube are in a straight line. Will this make a difference?
Old 08-17-2010, 03:12 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The ones that are straight are on the LB, not the Sedan...best to do a search for head unit replacement to get you started or else a search for replacing the climate control lights...
Old 08-17-2010, 03:30 PM   #5
JCHanlon
Drives: 2007 Sedan
Thanks!
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
wanting to paint my dash flat black but have a question removing knobs YarisSedan DIY / Maintenance / Service 0 07-08-2009 01:55 PM
Trade upgraded radio and dash for base radio and dash??? Yarisguy13 Items for Sale by private party 4 09-17-2007 06:32 PM
dash problems...help needed foggy08 DIY / Maintenance / Service 1 01-25-2007 08:04 PM
Removing A-pillar/partial dash H8SGAS DIY / Maintenance / Service 0 09-02-2006 09:03 PM
