Old 08-27-2010, 04:25 AM   #1
Toby Unna
Drives: Yaris GS
Yaris Stuttering/hesitating & engine light on!
Hi all, new Yaris owner - it's a 1.0 on a W-plate.
The engine light came on soon after buying. Plugged the laptop into the OBD port and it says code p0172, mixture too rich. Car runs fine when cold, but after a few minutes' running and from then onwards it stutters/hesitates badly if you push the throttle hard, then picks up after a second and goes ok, though it does feel quite flat (even for a 1-litre!)
Cleared fault codes and turned the engine light off, and it's stayed off for 100 or so miles, but the car is still running poorly.
I removed the AFM and cleaned the hot wire, to no avail.
I've searched around and read that stuttering is a common Yaris issue, but wondered if anyone has any pointers before I start replacing bits hat could make the mixture rich - AFM, coolant/air temp senders, O2 senders?
Maybe worth mentioning that the average MPG readout on the trip computer seems pretty good - ~50mph at a 60mph cruise
Thanks!
Toby Unna is offline   Reply With Quote
Yaris Engine Shake Roth5150 DIY / Maintenance / Service 12 04-18-2010 02:23 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
